If you or your company uses a Xerox scanner/printer then you may need to check that it is not subtly engaged in substituting wrong numbers. Apparently this JBig software bug goes back to the very early noughties. It could have impacted on any scanned document including those used for construction, financial audits or legal cases!
I am still not sure how you fix this bug, it needs a firmware/software update from Xerox.
