Why I miss MM forum
Forumite Members General Topics Other Stuff Why I miss MM forum
  • #422
      Over recent years, I have asked many questions, mostly linux related. Sometimes I forget the answer, but if I started the topic, I quickly find it and read it all again. Generally I copy the significant stuff to a file on this machine, but not always.
      Right now, I want to recall how to make Epub files immediately readable on my Kob0 Touch. I can’t find a copy of info here, and no access to MM stuff.
      Of course, without all the hardcore contributors finding us and moving here, quick useful answers may become difficult or impossible.
      Just remembered it was “Calibre”, so maybe a google search will help, once I confirm it is present in Mint 17, or download and install it.
      Les
      #423
        Why can you not access MM?
        #424
          P.S CalIbre is available in mint.
          #425
            mm is still where its always been. just dont use your old bookmarks as they wont work no more 🙂 o and clean your cache if issues persist!
            #427
              Firstly, having remembered it was Calibre, it is now installed and AOK.
              Secondly, I was unaware that MM was accessible. I had seen odd comments here suggesting some access, but never got beyond the rotating “whirlwind”. It is all down to old links? I will try again now.  Les.
              #428
                No luck, can somebody give me a link that gets access? I googled for MM, and tried their link to forum, but any attempt to access any sub forum brings the slow whirlwind back.
                #429
                  Les – do you have MM bookmarked still and have you tried clearing out any cookies/cache using something like ccleaner. A few people have had to clear out all trace of previous access to the site and start afresh. You might also need to “re-register” your password, this is simple though – they email you a link and then just use the same PW as before.
                  If the Missus’ PC hasn’t been used to access MM before you might give that route a try, just for elimination purposes.:)
                  #430
                    If your on mint you may need to give bleachbit a try to clear your cach, works a little like ccleaner on windows.
                    #431
                      Right, thanks for that both of you.
                      I tried Tamara’s laptop, no problem.
                      I cleared all history on mine, put the address in, and Voila, everything OK.
                      Busy now, will catch up later and see if I have missed anything, and try to log in then as well.
                      Cheers, Les.
                      #432
                        Glad it all worked out.:):) :good:
                        #540
                          Has MM forum gone t-u again, or is it just update time.
                          I just get the spinning circles right now.
                          Les
                          (and apologies for coming here to ask question, when I suppose we should be here all the time).
                          #541
                            It’s a case of clear your cach again 🙂
                            #606
                            isdaritisdarit
                              @isdarit
                              Crikey. my first post :yahoo:   had to say but we are now in bed with our new wife so don’t talk about your EX :negative:
                              #607
                                Welcome to the dark side  B-)
