Which QR Scanner?
Forumite Members General Topics Tech Android Talk Which QR Scanner?
  • #5310
    doctoryorkiedoctoryorkie
      @doctoryorkie
      Not for me. I’m a phone biff and hater.
      Friend wants a free QR scanner.
      No spam / ads.
      Permissions MUST be the bare minimum.
      Any pointers?
      TIA.
      Server N54L 8GB SSD 6x Spinners HD6450
      #5313
        They all will require quite a few permissions, as they need to to work. It’s needs camera, web, and file system at the very least. The down side of android showing you what permission is wanted, is that it scares people, historically on ios you want informed, so what you didn’t know, couldn’t freak you out. But most of the time, when you think why do they need these permissions there is usually good reasons for it. But if your a technophobe, you’d never think of the reasons, so they get freaked out.
        Some devs take the pee, with permissions, and you’ll see they get called out in the comments and will have a low rating. I use a simple method of picking somthing with high download figures and a good rating. You can’t go wrong really.
        I couldn’t recommend one over the other. I don’t keep one on my phone. Just dead the top one when needed then take it off. Probably need on a few time a year max.
        I see most contain adds now, about 6 down, in the search one called “QR code scanner” doesnt have adds. But I wouldn’t be put off but adds, as your in and out the app in seconds.
        #5315
          I’ve been using this one for years.
          #5319
            And me, probably got the heads up from you!
            #5321
              That was the original Barcode scanner, one or the first apps in the market place back in the 1.1 days.
              That would if been on my origanal android software list on mm.
              #5328
                @doctoryorkie
                Ta much, fellas.
                I had already looked at that one in the store.
                I will pass that on and report back.
                I can’t believe we are six posts in and still on topic. B-)
                <span style=”color: #ffffff;”>Cue a wag…</span>
                #5330
                  Tell him he can also do it on-line using the same  Zxing
                  #5331
                    I use QR Droid:
                    https://play.google.com/store/apps/details?id=la.droid.qr&hl=en
                    It does ask for a few permissions, but like Duke says, it’s for the functionality. There’s a version that needs less permissions too, but I haven’t used that one.
