Forumite Members › General Topics › Tech › PC Talk › What is Core 2 Quad
- This topic has 18 replies, 5 voices, and was last updated 8 years, 4 months ago by
PlaneMan.
November 3, 2017 at 9:05 pm #13249
What is Core 2 Quad
I thought quad meant 4 cores yet the
Product information
Technical DetailsOn this
States Core 2 Duo 1 core
JohnNovember 3, 2017 at 9:39 pm #13250What CPU are you looking at John?
November 3, 2017 at 10:10 pm #13251sos Dave The Word On This was a link I try again
I am after a cheap comercial rig Dell Lenovo Compaq etc at least 4GB Ram Windows 7/10 2.5 – 3GHz Dual Core 2 Duo well the more the merrier.
i came across the above and thought Qaud mmm
From Amazon only (freepost)
£70 – £120
JohnNovember 3, 2017 at 10:40 pm #13256If 2.4 GHz, that is most probably a Socket 775 Q6600 ?
https://ark.intel.com/products/29765/Intel-Core2-Quad-Processor-Q6600-8M-Cache-2_40-GHz-1066-MHz-FSB
November 3, 2017 at 10:44 pm #13257Thanks Boris
It sounds good, It’s just that it doesn’t give exact specs just a quad and then single core.
If I have it thinking it’s a Q6600 and it comes as a single core they’re are covered.
on the page they are all Core 2 Duo even the said one with 8GB ram 1TB HDD
JohnNovember 3, 2017 at 10:53 pm #13259Although one of the questions/answers says it is a Socket 775 Q8400
https://ark.intel.com/products/38512/Intel-Core2-Quad-Processor-Q8400-4M-Cache-2_66-GHz-1333-MHz-FSB
Question:
the 8 gb ram model has not got anything writen down for the cpu speed why is this and also what actualy is the speed of it?
Answer:
I bought one, though I hate Win 10 compared to Win 7, and the only answer I can give is that my spec says it is an Intel 2 Quad CPU Q8400 @ 2.66, 2.66.Never trust an atom - they make up everything !
November 3, 2017 at 11:30 pm #13260Thanks Boris
The link says it has 4 cores, maybe not so bad lets hope it is the Q8400.
It’s confusing.
JohnNovember 4, 2017 at 10:09 am #13263That’s a very old piece of kit now John. I would be worried about the hard drive, although at 1 TB it can’t be original (the 160GB probably are).
Don’t be fooled into thinking that as it’s a quad it’ll be fast. In single threaded performance it’s about half of a modern dual core Pentium. In needs all 4 cores to catch up with the Pentiums two cores for things like video transcoding.
Still, it’s only £85 ?
November 4, 2017 at 7:58 pm #13274Thanks Dave
Maybe I have been fooled?
If all else fails I will have a TB HDD and 8GB Ram
I will have to see (I gave her the green light for my early xmasy)
JohnNovember 5, 2017 at 9:51 pm #13308It’s Amazon, so if it’s not up to scratch back it goes!
November 6, 2017 at 7:44 am #13309Good point Dave, the beuty of Amazon except you have to pay postage (not sold by Amazon)
JohnNovember 6, 2017 at 8:47 am #13311Distance selling rules John. If it’s not as advertised it’s their fault.
November 9, 2017 at 7:54 pm #13361It arrived not as advertised (it’s the ram) not sure if I should make a fuss.
Dell Optiplex 760
Windows 10 Pro
Q9400 (4 Cores)
1TB HDD
4GB Ram (not the advertised 8GB) shown in system information?
They sent me a reciept even that has 8GB on it.
JohnNovember 9, 2017 at 8:41 pm #13363Get in touch with the seller, might be a genuine mistake.
If they act a bit arsey send it back, if not take a partial refund, more than enough to get the extra RAM.
November 9, 2017 at 10:15 pm #13365PM I’ll get in touch then see what they say.
JohnNovember 9, 2017 at 10:51 pm #13369It arrived not as advertised (it’s the ram) not sure if I should make a fuss. Dell Optiplex 760 Windows 10 Pro Q9400 (4 Cores) 1TB HDD 4GB Ram (not the advertised 8GB) shown in system information? They sent me a reciept even that has 8GB on it.
Just to check, is it 64 bit Windows?
November 10, 2017 at 10:52 am #13378Thanks Tippon
Sys Info doesn’t say, according to SIV x64 it’s Running
Windows 10 x64 Professional Version 10.0 Build 16299
They have offered to send me more ram.
I note it has 1GB x 4 Single sticks in, not sure if there is another 4 slots though
Memory DIMM_1 Size 1GB Bits 64
DDR2 RAM DIMM Speed 800MHz Samsung M3 78T2863RZS-CF7 #06A4-5B92 Tag 020906Memory DIMM_2 Size 1GB Bits 64
DDR2 RAM DIMM Speed 800MHz Samsung M3 78T2863EHS-CF7 #528B-5362 Tag 020921Memory DIMM_3 Size 1GB Bits 64
DDR2 RAM DIMM Speed 800MHz Samsung M3 78T2863EHS-CF7 #1D31-9B81 Tag 020922Memory DIMM_4 Size 1GB Bits 64
DDR2 RAM DIMM Speed 800MHz Hyundai HYMP112U64CP8-S6 #E3B7-525D Tag 011004Cheers
JohnNovember 10, 2017 at 11:02 am #13380Edit: (to above)
They said (sorry) it should be 4 x 2GB sticks.
They are going to send me 2x4GB sticks, I don’t know if it will take them (at this stage) they must think so?
Edit: Edit: They say (sorry) it will be 4x 2GB not 2x 4GB
At least they are getting back to me.
JohnNovember 10, 2017 at 11:07 am #13383That seems fair enough.
