Warning beep on a Peugeot 206 1.1 2003 ?
Forumite Members General Topics Motoring Motoring Problems Warning beep on a Peugeot 206 1.1 2003 ?
Viewing 20 posts - 1 through 20 (of 38 total)
  • #22176
      For a couple of weeks I have been hearing a warning beep, just a quick short beep and it is intemittant.
      I then noticed when it beeps a light comes on (the dashboard) its a picture of an oil can.
      So I checked the oil and it seems fine, a neighbour said it could be the oil switch. I had a new switch a couple of weeks ago (around the time the beep started) I did put a ltre of oil in (just incase) I didn’t hear the beep.
      Today it beeped, the oil can flashed and I noted the Stop light flashed aswell.
      I sat waiting for it to bleep again, I moved the steering wheel and it beeped, the can flashed and the stop light flashed.
      So I moved the steering wheel again (right) on return all happened again. I kept moving (as above) the steering wheel and it kept happening.
      So now I am wondering if it could be the Powered Steering Oil.
      Or could it be something else.
      It’s worrying as I have a month of daily (Mon-Fri) hospital visits.
      #22177
        So now I am wondering if it could be the Powered Steering Oil. Or could it be something else. It’s worrying as I have a month of daily (Mon-Fri) hospital visits.
        John – the oil can light that comes on on the display is to tell you to either top up the oil or book a service, depending on your model. All cars tell different tales.
        Possibly it’s a loose connection or an intermittent wiring fault that’s bringing up the light when you move the wheel. Needs to be looked at, but not likely to be teminal.
        The one thing you can be reasonably sure of, it is highly unlikely to have anything to do with the Power Steering fluid. That rarely has a warning light dedicated to it.
        #22178
          Thanks JayCee
          I will get it checked out, what’s a service that’s a new on on me.
          I hope it’s a loose connection, glad it’s unlikely to do with power steering and glad it’s not treminal.
          Edit:
          In fact I did email the garage about it, never got a reply.
          #22180
            Good luck all round for next  week!!
            #22183
              Reset the light John:     http://tinyurl.com/ybo9mh6q
              T’other John (JayCeeDee) is right, only top range high class motors have Power Steering fluid warning lights and not many of those. But if you do decide to check the PS fluid, do it with engine warm and car on level ground. Don’t worry if it’s a little below level, it won’t matter unless it’s well down.
              Good luck and good results from next month’s hospital visits.
              #22186
                Thanks JayCee
                Thanks for the link Bob, I have read it can’t see how to reset the light.
                I will check the PS Fluid on the flat when I get to moms (warm engine)
                Thanks for the good lucks, she finished the chemo, now has radio for 4 weeks at another hospital, under another consultant. Meanwhile she re starts her injections (at the local hospital) to finish May 2019, I say restarts as they stopped due to her heart.
                Due to family genes, well that’s another story.
                #22187
                Mark TurnerMark Turner
                  @turner74
                  Forumite Points: 12
                  Hi John
                  Was your oil level normal i.e on or near the max line on the dipstick before you added another litre of oil? If so you may have too much oil in there. The original fault could be a faulty oil level sensor as if i remember correctly the service light shows up as a spanner on that car.
                  Cheers Mark
                  #22188
                    The oil looked normal on the dip, except I struggle to see it (it’s that fine) I stroke my finger ove the dip and oil is on my finger. As the oil light kept coming on I topped it up and at first I thought it stopped it. 24hrs on it came back. Maybe it’s sfter a run and all is warm.
                    I don’t see a spanner, just an oil can and Stop sign lights up.
                    It is only a flicker and a short beep, intemittently. I can now make it happen by turning the wheel.
                    #22194
                      Iirc the 206 has a small lcd display, think it’s the odometer ect.. On that screen you get a service spanner when it’s needed. It’s just a button combo you cancel it like on all cars.
                      I mention this, so you can rule out it being a service reminder.
                      If you have checked the oil, and the light stays on then your oil is fine, and that will be a sensor issue. The beeping, im not sure off. But I think the 206 beeps when you leave the key in and open the door, or if you leave the lights on when you remove the key.
                      Is the beep like them beep tones? (not sure if the pug has more than one tone. My car has a few all annoying tones.) if so the beeb may also be a sensor issue.
                      Saying that of youre getting more than one sensor issue, it may be down to being not a faulty sensors, but fault in reading of them.
                      In the same spirit of fixing a rattle by turning the radio up (you can have that tip for free lol), I’d simply find the buzzer and snip the wire. It would cost to much to trouble shoot.
                      What is a cheap way for you to troupe shoot is by getting a cheap obd2 adapter, and via your phone reading the fault codes. (2 to 5£ on eBay and Amazon)
                      I’d of sent you mine, but I lent it my brother in law and he went to Afghan!
                      #22198
                        Corrosion/bad earthing can really screw up sensors, and is something to investigate if more than one sensor is involved.
                        #22203
                          Agreed, wiring or earth are most likely with a dodgy sensor as a runner up issue.
                          #22214
                            There is plenty of Power Steering oil, so it’s not that.
                            Thanks Duke
                            The Beep is like when you leave the keys in and open the door, but only a single beep. It is a warning, its the same beep when I run low on petrol.
                            That tip is mine and has always cured by turning the radio up. Out of respect I don’t have the radio on as I arrive home.
                            It is often now and again and not for long so I wouldn’t have time reading the fault codes. I think you need internet (or is it WiFi) for it to work on the phone.
                            Thanks Ed & Richard I have further investigated
                            It appears when the engine is hot (the temp is over half way) and the fan comes on, it beeps the oil can flashes, the stop light flashes and I have learned how to create it.
                            Under the above, if I turn the steering wheel right and back again, on the way back the above happens.
                            Thinking back this started after a new oil switch was fitted, so I went back (to the garage), with the engine hot.
                            I left the engine running, they had a look and then took it in the garage.
                            They said the new switch wasn’t fully working with the oil and they need to change the oil & switch?
                            #22217
                              Sounds like the garage messed something up, probably something simple like a loose connection that could be rubbing on the steering column. Total guess.
                              Whatever the problem is as it started after the work was done by the garage they have to foot the bill. Unless they can prove you did something, prove is the key word.
                              #22222
                                I am a little curious, it’s booked in for Wednesday so all should end good.
                                Edit:
                                I had an oil/filter change, inherited an oil leak, had the leak fixed (oil switch)  inherited an intermitent problem.
                                Not to forget I already had a new oil switch about February.
                                #22243
                                  That is an ongoing problem JB. First a leak, then 2 oil switches, then the light coming on. If all of that had come into my workshop (and similar problems did) I would be investigating the housing that the switch screws into. A repeated problem in the same place? I would be digging deeper, had it appeared in my workshop. I would first check the condition of the threads in the housing and the switch, also the condition of metal surfaces between housing and switch. Depends whether they “find” another cause, be sharp with them: why was this not picked up before?
                                  Good luck.
                                  #22246
                                    Thanks Bob
                                    I hope they know and will sort it, I won’t know till I try to re create it, after it’s sorted.
                                    It’s easy to create it, I filmed it today, the sun is on it, fainrly is the right corner is the oil light. I even noticed the battery is flashing.
                                    Crazy warnings
                                    #22252
                                      John I found this, which might help you find what all your warning lights mean:
                                      http://tinyurl.com/y7knf34b
                                      There is a possibility that your problem may be a dashboard fault, in what I think is a PCB behind the dash (so long since I worked on this stuff!) Reason why I say that, is the Brake warning light flashing. Those mean a problem with brakes, have you had any problems during braking? Any grinding noises from the front disc brakes, pulling to one side on braking?
                                      #22257
                                        Thanks Bob
                                        The only problem I have had (since I had new pads) is screeching (as I drive) I took that back no end of time, it still does it now (intermittently)
                                        The clock illumination (when the lights are on) is dull. The clock keeps going off and is replaced with the temperature, that is mainly in the winter. That really annoys me, I know how cold/hot it is, I don’t know what time it is.
                                        I can’t think of any major problems, when they arise I get it seen to, safety is my priority, mainly for any passengers who put there trust in me.
                                        When I last took the car it hadn’t warned, I left it running, I can only assume it started when they got to look.
                                        I am determined to get this flashing sorted, they have offered a fix so I will give them the benefit of the doubt.
                                        It did only start since they changed the oil switch, it did fix the oil leak.
                                        #22469
                                          @turner74
                                          Forumite Points: 12
                                          Hi John
                                          Did you get it it fixed and find out what the problem was?
                                          Mark
                                          #22485
                                            John, the screeching is probably from your pads: if you have new pads fitted, there should have been grease thinly applied to the back of the pads. I used to use “Copperslip” which as its name suggests, is a copper-based grease. It stops the metal backing of the pad contacting the metal of the caliper. The Copper base is to stop corrosion. It is also applied to the pins that hold the pads in the caliper, but has to be applied very thinly, so as not to get onto pad braking surfaces.
                                            Available from most Auto parts shops, this is Halfords:     http://tinyurl.com/ybsj9ejf
