W10 Virtual Secure Mode
Forumite Members General Topics Tech Windows Talk W10 Virtual Secure Mode
  • #42937
      I just read in my new edition of the Windows Internals part 1 book that versions of W10 that support Hyper-V now also support a new Virtualization based security architecture.
      With this model the OS, both user and kernel mode portions, is split into two parts called Virtual trust levels 1 and 2. Both VTL0 and VTL1 run as separate Hyper-V virtual machines  with the most secure sections running on VTL1.
      I would like to have a play with this but I only have W10 home where I am so I can’t 😬. Apparently it shows up under Add Windows Features as Isolated User Mode if you would like to see if your system is using it.
      You will also need a fairly recent CPU that supports Second Level Address Translation and an I/O MMU.
      #42939
        W10 Pro licences are cheap enough on E-Bay but make sure you get one that supports upgrading.
        Sometimes even then the Activation servers don’t like it, but there is a workaround for that (it involves doing the first stage offline) which has always fixed the problem for me.
