  • #14239
      TVFox Antenna
      Anyone got one? any good? what TV do you get?
      #14241
        Had to google it – appears to be a high-gain indoor digital TV antenna. Can’t see it being much use to be honest – unless you can’t get an aerial connection any other way. The blurb sort of implies you’ll get a load of cable /premiumchannels free – but you won’t – especially in the UK. There’s a lot of similar/clone devices on Amazon/Ebay so if you want to try one I’d go with an Amazon-sourced one with easy returns.
        #14249
          Thanks Blacklion
          I think I was reading the hype as usual, won’t bother my aerial works fine.
          #14443
            As it was mainly for dad I did try one (off Amazon) it arrived today, Amazon are fetching it back tomorrow (next business day)
