Touchscreen not working
Forumite Members General Topics Tech PC Talk Touchscreen not working
Viewing 20 posts - 1 through 20 (of 32 total)
  • #36700
      Touchscreen (on a 7″ Fusion5 Windows 10) not working.
      First off it wouldn’t boot into Windows, using Windows recovery it re installed Windows 10 (like a fresh install) I had no Touchscreen I have checked everything I can and still can’t get it to work. Even on start when you swipe up it won’t swipe. Their are no conflicts in device manger, (it states) touchscreen is working properly.
      The screen isn’t cracked and no visible damage.
      With a USB mouse it works perfectly Windows is updated including V1903.
      #36710
        Did anything happen before things went wrong, like a Windows update ?
        #36712
          Same problem here John:   https://tinyurl.com/y5bt7gej
          And here:   https://tinyurl.com/y4o9evg3
          #36715
            IF you can find out how to do a factory reset then do so.
            #36722
              Thanks Graham Previously (before new install) I didn’t have this I only know since re install of Windows 10 the touch screen isn’t working.
              It doodles along nicely with a USB mouse.
              Thanks Bob I had a probe slightly different but no solution.
              Thanks Ed
              There is no factory reset, I think you send it back to fusion and they sort it, costs more than I paid.
              I have contacted fusion5 twice and they don’t get back to me.
              I once asked Fusion5 (about another) how to reset and was told to use Windows 10 Recovery, but that doesn’t fix the touch screen.
              #36724
                Think when you ordered this John, you were advised that an Android tablet would be much better. I have the older 8″ version of this Lenovo Android tablet and have had it for 3 years now, I love it:
                https://tinyurl.com/y2uldl59     £49.99, although the 8″ is a better tablet at £89.50.
                There is an Android version of the Fusion5 at £42.47:     https://tinyurl.com/y3aybzxq
                #36730
                  My off-the-wall guess is that all the Fusion pads have the same Android chipset sitting underneath. IF this is the case then normally a factory reset uses a combo of the ‘home key’ + ‘vol-up’, and or ‘vol-down’ all pressed together and held for 6 secs or so. That sometimes drops you into a menu that allows you to reload the drivers for specific devices.
                  Up to you whether you try as there is a finite chance you can screw up the settings.
                  #36732
                    As you have a device with an ARM CPU (I can’t find the specs but you must have if it can also run Android) then you will have a Universal Windows Platform version of Windows and that has some very odd UWP drivers 🙄. If the driver is not installed in exactly the right way (not the normal way) then it will appear to be installed but it won’t be properly linked into the OS so won’t work.
                    The only way to properly install UWP drivers is to run the installation package EXE or to let Windows update do it. It may be worth uninstalling the existing driver, so the touch screen shows as unknown device, and then doing a forced Windows update check.
                    Just a thought 😁
                    #36733
                      sos Bob
                      This is not the one your talking about, I had it off ebay as a non booter (spares/repair).
                      I repaired it (now boots) I just can’t get the the screen to react to touch.
                      Ed it’s not an android (Windows 10), although the procedure does work for in which I have already used to restore windows via Update & Security / recovery / advanced startup / restore windows from a system image.so it must have recovered from an image, it just won’t swipe since recovery.
                      It’s though the touch screen wasn’t in the image or maybe it’s never worked.
                      #36738
                        +1 to Graham’s comments. I said Android for simplicity but meant ARM.
                        #36742
                          Thanks Graham I did uninstall the driver on re boot the driver was back. I will try again
                          Thanks Ed It probably my understanding had you said arm I wouldn’t understand either.
                          Edit: I uninstalled the driver ran WU it didn’t see it, re booted the driver was back and working properly but still no touch
                          #36745
                            John – the problem with UWP drivers is that the yellow exclamation mark sometimes does a ‘Boris’, and does not tell the whole truth. You could try working through this simple list of possible remedies.
                            #36749
                              Driver Easy may be a good idea 😁
                              In the meantime does your touch screen driver show up under settings>apps>Windows apps and features ?
                              #36750
                              BorisBoris
                                @boris
                                I am most distressed at this slur on my impeccable character. 😎
                                #36751
                                  Sorry, I meant the mendacious one, perhaps doing a BoJo would have been better.
                                  #36752
                                  BorisBoris
                                    @boris
                                    Apology accepted
                                    #36767
                                      Thanks Ed
                                      I tried all the possible remedies, easy driver downloaded 6 updates they went into C: User / App Data / Local Roaming / Easeware Driver Easy / Drivers
                                      I can’t find them in Local, I think it wants £50 before I can install them.
                                      Graham the touchscreen driver isn’t where you suggest.
                                      #36772
                                        I had a feeling the driver package wouldn’t be listed. If you DO manage to get a driver it should be a PACKAGE and it should show up 🤔
                                        #36773
                                          On the other hand, no one has much experiance of UWP yet so it could do anything 😀
                                          #36891
                                            New faults since starting: include
                                            Windows 10 Revovery no longer works, the battery icon is missing, you can no lorger see if it’s charging etc and the camera is missing. These were there when I first started (after refreshing from Windows 10 recovery)
                                            Sadly it won’t boot USB so I can’t use a USB DVD Rom to boot.Could this be one of the original faults?
                                            I have tried everything.
                                            Is it time for the bin.
