Thunderbird Backup advice
Forumite Members General Topics Tech Software Talk Thunderbird Backup advice
  • #7567
    oldtimeroldtimer
      @oldtimer
      I have used TBird for a number of years and never found a way to backup my messages, mainly because I cannot find them. I know where the PROFILE is but I can find no sign of messages within it.  Still, they must be there hiding behind another name.  What I would really like is a back-up programme that would do the job for me simply cleanly efficiently and reliably.
      I have found several offerings on the web, but they seem to come with a warning that they do not work properly and “should be used at the users own risk”
      I guess I am not the only one to use TBird so hopefully some one can give advice.
      Maybe even any alternative email progs.  Again I have found one or three but they seem to require me to sell my soul to one or other of the data grabbing devils such as MSoft, Google etc
      The big advantage of TBird is that I do not have to join anything.
      Its easy when you know how
      #7568
        Mozbackup http://mozbackup.jasnapaka.com/ I’ve used it a lot over the years to migrate TB from one PC to the next.
        #7569
          PROFILE links to a hidden folder. I think you use Ubuntu or Mint and the mail folder for these is in:
          (show hidden files)
          your Home folder->.thunderbird->some weird folder e.g. xz7feqqz.default. (just look for a folder some name.default. You can open this folder and only copy Mail if you like but I do not recommend this approach)
          you need this plus another file in
          your Home folder->.thunderbird->profiles.ini
          Copy both the folder and the profiles.ini file to a thumbdrive. When you want to restore just install TBird, run it once and fill out your mail details (important), then shutdown TBird and overwrite the .thunderbird files with the contents of your thumbdrive (you can ignore the crash reports stuff).
          Simple quick warts and all backup – backup for Windows is similar but I cannot remember where ‘profiles.ini’ is kept.
          #7571
            +1 to Dave’s advice. I use that programme to back up everything on T’Bird – I also used it for Firefox when that was my default browser ( now on Chrome ). I seem to remember some cautions/warnings expressed about no longer supported or up to date, but I used it successfully when I moved to a new W10 PC last year.
            #7576
            oldtimeroldtimer
              @oldtimer
              Thanks all.
              I will have a look at MOZBACKUP on the strength of that even if the website says “USE AT OWN RISK”.  After all, you cannot all be wrong can you? :good:
              #7577
                I’ve used it on a W10 PC this year.
                #7579
                oldtimeroldtimer
                  @oldtimer
                  Done.  Downloaded and installed.  Backup run. Now I have to wait for an emergency  LOL
                  #7580
                    I must admit I thought the OP used Linux, but I see I was wrong. Mozbackup doesn’t work for Linux but is a good choice for his Win7
                    #7582
                      You’re thinking of Old Les.
                      #7611
                        OT don’t you have a second pc to can try the back up on? Id have to test  out.
                        #7612
                          You don’t need a second PC, just a different user.
                          #7622
                            Not disagreeing with Dave – just wanted to tout the Portable Version. There are times when this can come in handy.
                            link
                            #7656
                              Not disagreeing with Dave – just wanted to tout the Portable Version. There are times when this can come in handy. link
                              Seconded. I use the portable version as my main mail client, and copy it to my pen drive every so often too. On the off chance that my house burns down, I’ll still have a copy of the message from that lovely sounding Nigerian Prince 😉
                              #7670
                                For completeness, on Linux your profile folder itself will have inside a Mail folder. Simply copy it somewhere secure, and job done.
