Forumite Members › Forumite News & Feedback › Website feed back suggestions › Forums: Request features or Report problems. › Submit slow
- This topic has 10 replies, 6 voices, and was last updated 8 years, 1 month ago by
RSB.
January 16, 2018 at 10:11 pm #15761
After creating a topic/reply it seems to take an age for the submit to go through.
JohnJanuary 17, 2018 at 7:14 am #15764No problems here. Probably an Internet connection glitch.
January 17, 2018 at 7:28 am #15765Thanks Ed
Never thought of that, must be.
JohnJanuary 17, 2018 at 1:43 pm #15774No it isn’t as I just had the same problem. Took about 30 seconds to load my response.
The PC Advisor Forum had a similar problem for a couple of months which eventually turned out to be caused by invalid or expired links in members posts. Just for info as this is such a new forum it is probably not the likely cause.
January 17, 2018 at 5:37 pm #15787Just made 3 submissions, no problems here.
I'm out.January 17, 2018 at 7:23 pm #15792Spectre/Meltdown updates have been causing a mass of problems particularly to Cloud setups. Ars LInk
I’m not suggesting that Lee has had these problems, perhaps the IP nodes you get routed through are having issues. This would explain different experiences at different times as routes change on the fly.
January 17, 2018 at 9:41 pm #15794I do not have the fastest upload speed in the world but earlier this evening it was almost at dial up speed. Now it is something like 5 times faster going up and about faster by about 15% for downloads. I suspect that loads on the network are not being managed too well for some reason or another, maybe it is congestion maybe the weather may be something else.
January 18, 2018 at 8:15 am #15804RedHat makes up a large proportion of the commercial server world. Although noone but an idiot puts in fixes without thorough testing, losing a small proportion of them could cause a web slowdown, and it looks like the Spectre fixes (El Reg link) are at the slightly flaky end at the moment.
January 18, 2018 at 10:06 pm #15814No problems with my speeds*, always around this area:
*Except I wish they were much higher, of course, but no one in my vicinity comes even close to those speeds. It’s a stable service and a 25ms Ping ain’t bad.
I'm out.January 19, 2018 at 6:59 am #15817When I started this thread I was using Virgin BB. I am now using Sky’s free BB and the submit time is still slow.
JohnJanuary 19, 2018 at 8:23 am #15819There is a problem with the submit and I have noticed it for a few weeks and will be looked into once I find the time.
I see you got round using the support area this morning John.
This thread is closed for business now.
- The topic ‘Submit slow’ is closed to new replies.
