Smart phone payg
Forumite Members General Topics Tech Android Talk Smart phone payg
  • #28490
      I ham temp using a nokia1 smart phonphone, with a 02 payg SIM. I have an SD card. In with music on. I cant find them on the mobile to play them. Does this only work with a contracted SIM and not payg. Ai am using above to post this and I am not responsible for any errors (spelling etc)
      Now on Desktop
      Also it won’t connect to PC Nokia1 Suite.
      #28491
        Install Es File Explorer, that’ll let you find the SD card.
        #28493
          It will work with NO sim. If its a fairly recent android phone have you looked under Apps>Tools>Myfiles ?
          #28494
            Thanks PM I am installing it.
            Sos Duke I found the music under my files. It’s the icon / player – My Music I can’t find.
            #28496
              On some new phones you need to look in the apps and put the music icon onto one of your home screens.
              #28497
                I notice the Nokia 1 runs Android Go so you may not have the usual music player installed. You can get Google Play Music from the play store or just pick something else like PowerAmp trial.
                #28500
                  Thanks JayCee
                  I have looked in the apps and it’s not there.
                  It seems that must be it Graham. I will have a look at players (power amp)
                  #28506
                    If es file explore can’t see it, I don’t know what will
                    Ive never heard of the situation JC discribes. Es should see all the files on your device or sdcxcard
                    #28545
                      Es file explorer does the job, it comes with ads though.
                      #28547
                        The pro  version doesn’t, and is worth it’s price just to support the dev team alone. It’s a great app, and quite powerful.
                        #28621
                          Cheers Duke I will look into Pro.
