  • #8981
      I cannot get the top right search bar to return anything – any one else having problems?
      I was searching on DNA and got nothing, then tried Brexit which should give loads and still got nothing. Is it just me?
      #8982
        Its working for me, searched brexit and loads come up. Ill take a look none the less.
        #8984
          Nothing Found
          Sorry, but nothing matched your search terms. Please try again with some different keywords.
          Brexit
          Still not working for me – Firefox 53.0.3(64 bit) running within Debian (which should be pretty much the same as Mint etc)
          #8986
            It just worked in FF53.0.3 on Win10 even without logging in. Are you on a VM at all ED – that might make a difference?
            #8987
              Works fine here on Chrome OS.
              #8989
                Yep I use VM but that normally makes no difference.
                #8990
                  I have checked all the FFox settings – I’d already given Forumite a clean bill of health on everything. Odd!
                  #9068
                    I suddenly cottoned on – I was using the ‘wrong’ search. The one in the black top bar does not work at all. it doesn’t matter what term I use. I’m not really sure what it is supposed to do.
                    The search in the Green bar works fine.
                    Sorry for the confusion!
