Sabrent USB Sata Connector
Forumite Members General Topics Shopping Electrical Sabrent USB Sata Connector
  • #22134
      If you are looking for a low-profile fast USB2/3 connector for an SSD then I recommend the Sabrent connector. It is especially good for adding a cheap SSD to a Raspberry Pi.
      If you have ever done this, you will cuss that coupling up a SSD costs you two valuable USB ports. The Sabrent only needs one (being a USB 3 connector), and takes up a lot less valuable real estate.
      I’ll confess to being marginally concerned at possibly overloading a USB2 port, but it doesn’t and if anything it is faster than the usual  clunky USB2 connectors.
      Recommended for Pi service or for connecting a removable backup SSD!
      #22173
        Mine arrived today, hopefully I’ll get some time to have a play over the weekend.
        #22181
          From experience, setting up an SSD boot on a Pi requires a little bit of art. I do the following, but there may be better ways.
          a) I use Linux and GParted to format the whole drive as Fat32. Windows will not let you do this without using the command line.
          b) I then use Win32DiskImager.exe to burn the .img file onto the SSD
          c) I then boot the Pi3B with the SSD installed. If a Pi3B is used it just works. For a Pi3 the mobo needs initialising first link
          d) Allow it to boot twice as it does something with the boot partition.
          e) After the second boot, change the Pi password and expand the partition. It will say it does not know how to do it, but ignore the warning as it ‘probably’ sets a flag.
          d) I then shutdown, remove the SSD and use gparted to expand the Home Pi partition,
          e) Reinstall the SSD then use as normal.
          I’m not sure if all these steps are required but when I follow them it works whereas I’ve had failures when trying shortcuts. I recommend using the ‘official’ power adapter as I’ve had problems with Chibay ones.
          #22184
            I’m using my POE switch and a splitter so hopefully power won’t be an issue.
            #22364
              Too hot to do anything in the workshop at the moment! No windows and a south facing non opening black metal garage door.
              #22367
              BorisBoris
                @boris
                Just use Linux then ? ?
                Sorry  – just couldn’t stop myself !
                #22371
                  Dave, I feel your pain about the heat. My little house is on a NE/SW line, front to back.
                  The car out the front gets baked in the morning, as does the kitchen and bathroom, then the living room (patio doors) and bedroom get cooked as the sun goes over the house. It’s so hot I’m not switching lights on unless absolutely necessary.
                  #22392
                    My bungalow lounge window is huge, takes almost the whole frontage up to the door. It faces South and slightly West, which I would as a one-time Junior Deckhand, classify as SBW, or South by West. We leave the curtains wide open and all the doors too: if the weather shows even weak sunshine, it heats the whole house and saves on heating bills. Some winter days we are able to turn off the GCH. It has been hot the last week and warm in the week before, but not as hot as the rest of the UK, as the East Coast is now subject to Northern breezes as the High Pressure area has moved West. That is perfect for SWMBO and I, we can walk along local beaches with a nice cool breeze. I have to avoid hot sun anyway, as with the Chemo I am told that I will burn easily. Something that never happened before, I just go browner and browner.
                    We have temp’s of between 19 and 21 atm, which is fine for us. Today I drove up in blue skies and sunshine to Grimsby, for Day 1 of Cycle 2 chemo, sat in the Hospital lovely sunny garden, got my next supply of Capacetabine tablets and am on my way again. 3 more weeks and a holiday, Cycle 3 restarts after that. Feeling good.
                    #22420
                      We’ve got the same layout. By about ten the upstairs living room and front bedrooms are too hot, 27+ degrees. Luckily the downstairs stays fairly cool. By the evening, the kitchen and back bedroom are too warm, and the front rooms still haven’t cooled.
                      Thankfully there was a nice breeze today, so even though it was over 28 degrees, it didn’t feel it.
