  • #23866
      @bdthree – Lee, I’ve just read this Topic and on returning to the Topic page and refreshing, it still shows as unread with the black vertical bar on the left hand side.
      Lee, I’m noticing the same on “Fake News” and “Embedded URL’s………..” – the problem may be around the “Fisrt Post always visible” change – they’re both showing on EdP’s posts with 1 voice and 0 replies.
      #23887
        I agree with JayCeeDee, the post above showed up as unread when only his post was visible.
        #23888
          Immediately my post (above) was made, the unread/read function worked as intended. Good catch JayCeeDee.
          #23892
            I can live with that. Just tried it my self and works as intended. As for the links there also showing for me as intended. I’ll clean my cache later and see if I can re-produce the problem.
            #23893
              Seems to be working fine for me.
              #23926
                And me.
                #23952
                  To see the problem you have to look at a brand-new post that someone else has made and before any other posts are added to the thread..
