New kit not working
Forumite Members General Topics Tech PC Talk New kit not working
Viewing 18 posts - 1 through 18 (of 18 total)
  • #68599
      I purchased new kit to build a computer, I have put it together over a week taking my time and doing it to the letter. Last thing I had (today) was ram. I put the ram in and powered it up with a Windows 10 instaltion USB in.
      Their is a light on the mobo the CPU fan is spinning and that’s as far as it goes.
      Here’s the kit
      Mobo
      CPU
      Ram
      SSD
      #68600
        Have you checked the bios settings? It should at the very least say that the USB drive is the boot device.
        #68602
          cheers Ed
          I can’t get into the bios nothing is working other than the fans and a light on mobo, not even any beeps.
          I was thinking could it be lack of power to the CPU the PSU only has 4 pins so I purchased this
          maybe it needs a PSU with 8 pin plig?
          #68603
          BorisBoris
            @boris
            John, as I said to you before. This  i3 10105F processor you linked to does not have integrated graphics – so you’ll need a dedicated graphics card.
            #68605
              cheers Boris
              I remember, it has a socket that my plug went in. Shows how much I know I should have listened.
              Is it just a PCIe I need
              #68607
                will this do or does it need to be dedicated
                #68608
                BorisBoris
                  @boris
                  The slot is marked PCI_E1 (the long one – under the CPU and above the motherboard battery).
                  That Dell ATI Radeon R5 240 card originally dates from about 6 years ago ?
                  It has DVI and DisplayPort outputs.
                  #68610
                    Thanks Boris
                    Thanks Boris
                    I am clueless
                    When I search PCI_E1 it throws up some like when I click the link it doesn’t state as PCI_E1, could it be E3 (further down)
                    I don’t want to get the wrong type which is 6 years old.
                    #68611
                      looking deeper it’s getting frightening did I buy the wrong CPU as onboard graphics (CPU required)
                      This is my first new kit project, maybe I should have left it.
                      #68614
                        is this what I need,
                        When I search dedicated they are far to expensive.
                        I am nearly giving up and put it all in the box/s. I fetched the mobo box out (ready to pack) and changed my mind for now.
                        #68618
                          John, that looks to be far too big for your case, Dave said in your ‘Calling ricedg’ post:-
                          It must be half height (aka low profile) as your case won’t take full height ones. So you must make sure it does have the right brackets in the box.
                          Asus GeForce GT 710 2GB GDDR5 £50 Only get this if you can’t afford anything else.
                          Gigabyte GT 1030 Low Profile D4 2GB £80 All the current GT 1030 cards have only digital output i.e. no VGA. So if you have a VGA only monitor you’ll need an adapter like this for £8.
                          #68619
                            Thanks JayCee
                            O yes I forgot what David said (when it comes to it) glad you pointed it out.
                            Thanks for the suggestions I will have a look.
                            #68620
                              Is this one any good
                              It does match the suggestion, so maybe a silly question.
                              #68623
                                That looks like the Low Profile version of this one I’m looking at for my build.
                                Just make sure that your monitor has an HDMI port ( or Display Port ). If it only has a VGA port you may need the adapter Dave also referenced.
                                #68624
                                  Lovely JayCee thanks
                                  I wish I was going for the one you’re having, maybe 1 day I can get a bigger case. At the moment I use what I can for now.
                                  I have only VGA but I do have the adapter.
                                  Hopefully I can fire the rig up soon.
                                  #68625
                                    All good John, hope it works for you.👍👍
                                    #68632
                                      Thanks JayCee
                                      I hope it does work, once gfx card is in?
                                      A confession
                                      The  i3 10105F was cheaper (by half)  than the i3 10105, so I then forgot all about integrated. However I should have added up the savings I could have made not buying a GFX card. I was trying to save but ended up not.
                                      All becuase of an F, that I was warned about.
                                      Anyway my thanks go to all  participants in this and my other recent threads.
                                      #68797
                                        Asus GeForce GT 710 2GB GDDR5 £50 Only get this if you can’t afford anything else. Gigabyte GT 1030 Low Profile D4 2GB £80 All the current GT 1030 cards have only digital output i.e. no VGA. So if you have a VGA only monitor you’ll need an adapter like this for £8.
                                        Going back to the above suggestion I cheated a little (to save money) and purchased this as a cheap substitute. It’s in a gigabyte mobo. The mobo fires (I think) the HDD flickers, I can’t see it on a monitor, is the gfx card purchase not a good substitute for GT 1030 Low Profile D4 2GB.
                                        Using this
