Forumite Members › General Topics › Tech › Other Tech › Magnetic USB cables
- This topic has 16 replies, 6 voices, and was last updated 6 years, 3 months ago by
Tippon.
November 18, 2019 at 12:47 am #38335
Anyone know if there’s a standard for magnetic USB cables? Will the connectors from one brand work with the cables from another?
I’ve just bought one to try out, and I like the idea, but before I buy more I thought I’d better check. I can obviously buy from the same place, but I want to get some flashy cables for Alice’s kit, and also if the company I’m currently using goes under, would I have to start again if my cables break?
November 18, 2019 at 9:15 am #38336Apparently they all have chips inside, so no.
November 18, 2019 at 9:56 am #38341+1
https://electronics.stackexchange.com/questions/376536/why-magnetic-usb-cables-have-chips-in-them
All I could find about it is above.
November 18, 2019 at 12:57 pm #38344I think you’ll struggle to use them if your phone’s in a case as well as the lug that stays in the phone may not fit.
November 18, 2019 at 5:14 pm #38345My daughters Huawei has been in many a bumper case – fashion items – and seems to cope with the magnetic stub. The cases have to have a recces to cope with the plug head and the short length of the connection end.
I’ve just realised her phone is nearing it’s first birthday so something of a record. She either wrecks the screen or the USB socket. It’s also the first phone she hasn’t found something to complain about!
November 18, 2019 at 5:45 pm #38348Fair enough – never tried one Dave – and since I’ve been “Type C” am less concerned about b*ggering the socket by forcing the micro usb in the wrong way (which is what made me look at the magnetic option in the first place).
November 18, 2019 at 11:00 pm #38355BL that last bit: “… b*ggering the socket by forcing the micro usb in the wrong way …” resonates with me. My Lenovo Tab3 socket is quite loose due to {someone’s} impatience at trying to cram it in without checking that it was upside down. “I only wanted to check the BBC weather…” “OH Bowlocks! Look out of the window! It’s raining!”
I'm out.November 19, 2019 at 1:41 am #38356Thanks guys 🙂
It’s a shame, but not the end of the world.
I’ve got a C connector for my Honor 9, and it fits through the case better than the two normal cables that I use. It’s small enough to stay there too. I might just buy a load during the xmas / new year sales and be done with it.
November 19, 2019 at 3:28 pm #38370I loved the idea of these but they charge too slow for me.
I did get one for the car, but I couldn’t get android auto or apple cp to work with them. Now if I could get that working, I may put up with the slower charge speed. Maybe…
November 19, 2019 at 8:28 pm #38382Ths is the cable I bought:
https://www.aliexpress.com/item/32996527344.html
As far as I can tell it does fast charging. I’ll have a proper look tonight though, and see how much it charges in 10 and 30 minutes.
November 19, 2019 at 8:58 pm #38383Depending on your phone, when you plug it in it will tell you if its charging, fast charging or super charging, etc. Also the charge icon indecator is different for each. Subtle but different.
November 21, 2019 at 6:38 pm #38440My phone went from 27% to 45% in 12 minutes with the cable I linked to earlier.
November 21, 2019 at 6:57 pm #38442That’s good, does it work for data transfer do you know? If so it May do android auto also. Then I’m in, all day long.
November 21, 2019 at 9:37 pm #38447It definitely does data transfer, but I haven’t tried it with Android Auto yet.
November 22, 2019 at 6:35 am #38450Do you have auto in your car?
̶C̶a̶n̶ ̶I̶ ̶h̶a̶v̶e̶ ̶a̶ ̶l̶i̶n̶k̶ ̶t̶o̶ ̶y̶o̶u̶r̶ ̶c̶a̶b̶l̶e̶s̶ ̶p̶l̶e̶a̶s̶e̶?̶
Edit just seen you have.
November 23, 2019 at 10:29 pm #38490Do you have auto in your car?
I have, yeah. If I’d thought, I could have tested it earlier. We’re going out in the car tomorrow, so I’ll try it out then 🙂
November 24, 2019 at 2:45 pm #38508Just tried Android Auto and it worked fine. The only problem is that the connection broke when I moved the phone. I put it on my lap and a crease in my jeans was enough to break the magnet’s connection. I can’t see it being a problem if you’ve got a holder, but if the phone is likely to move it could disconnect.
