Posting here since I use Mint.
I use Draw for all sorts of stuff, including circuit diagrams, “engineering” drawings etc., but still only at basic stage.
I have a circuit I drew which I want to modify for another version of the same thing. It currently has 7 horizontal lines of different colours terminating in a connection block. I wish to shorten them and stick a crocodile clip on the ends.
OK, deleting terminal block is simple, followed by grabbing LH end of each line and repositioning it say 5cm to the right. However, it is easy to lose “horizontal”, and then I faff around with mouse getting final end location “just right”. Often I need to magnify page (+ on KB) to get exact position.
Since each line’s coordinates are written out below the bottom of the page, can I simply access those coordinates to give the line length reduction and position I want? It seems obvious to me, so I am sure it is possible. If so, how???
