Installing Mint 19 Tara
Forumite Members General Topics Tech Linux Talk Installing Mint 19 Tara
  • #23307
      I made a start with this install earlier today. Some problems, but this one here, rest in “Two into One”.
      I went through the install as normal. Possible clue to main problem:- Mint install wanted to install to my  250Gb spinner, which it identified as sda. I selected instead my 60 GB SSD which it identified as sdb. Install then proceeded normally.
      It announced install was finished, and that I should removed the install media (DVD ROM), then press ENTER. The drive opened, I removed the DVD, and hit ENTER. Then again, and again, with no response. Eventually I pressed the OFF button, then after it shut down, I pressed it again to boot.
      It ran thro to “Boot from CD –“, then just waited, and waited. Eventually, I switched OFF, Next Swtch ON, and  insert install DVD. I then selected “Boot from local drive”, and everything was OK. I did all the updates, had a general “look around”, then tried a restart.  Same again. I currently must start from the DVD then boot from local drive.
      Help Please!
      #23313
        Look at the boot drive settings in the BIOS.
        #23315
          Progress but no progress. I screwed a few things up trying to sort the Home / data thing, and meanwhile I came to the same conclusion as Dave (but from a different direction). I shut down, changed the two main SATA cables over,  expecting to sort out the drive identities, which it did. After checking the bios to be sure, I did a second install of Mint 19 Tara. This time it chose the 60gb SDD as sda, so from then on every thing looked OK.
          HOWEVER, with completed install, it then did exactly the same, with ENTER having no effect after removing DVD.
          I did the same as before, insert DVD, switch on, then select “Boot from local drive”, and here I am again, NO wiser.
          Les
          #23317
            Totally unplug the spinner and try again.
            #23324
              If you can make a boot (even via the CD), can you post the contents of /boot/grub/grub.cfg and /etc/fstab
              EDIT: So as not to make the post too long, examine /boot/grub/grub.gfg and just post the section that boots mint (you’ll need to scroll past the initial stuff until you find a section that looks like:
              menuentry ‘Arch Linux’ –class arch –class gnu-linux –class gnu –class os $menuentry_id_option ‘gnulinux-simple-f333c31e-b315-4d8f-aacb-68a03f08512b’ {
              load_video
              set gfxpayload=keep
              insmod gzio
              insmod part_msdos
              insmod ext2
              set root=’hd4,msdos1′
              if [ x$feature_platform_search_hint = xy ]; then
              search –no-floppy –fs-uuid –set=root –hint-bios=hd4,msdos1 –hint-efi=hd4,msdos1 –hint-baremetal=ahci4,msdos1 3a4bd46a-058f-4f23-bc8b-c7dc1e0512da
              else
              search –no-floppy –fs-uuid –set=root 3a4bd46a-058f-4f23-bc8b-c7dc1e0512da
              fi
              echo ‘Loading Linux linux …’
              linux /vmlinuz-linux root=UUID=f333c31e-b315-4d8f-aacb-68a03f08512b rw vga=795
              echo ‘Loading initial ramdisk …’
              initrd /initramfs-linux.img
              Ignore that the entries are different from mine, I’m on Arch.
              #23327
                Damn. Why does this forum not support [code][/code] tags?
                #23328
                  Dan, you just beat me to it, so just to say Dave is right as usual.
                  I meant to say last night that without the DVD, it said “entering GRUB rescue, but without success.
                  Anyway, after a late night, I disconnected the spinner, and it booted up without the DVD. Next I reconnected the spinner and it again booted up without the DVD, so that is that sorted.
                  Thanks both. Now for the sorting out of the HOME problem.
                  I still need to mount the spinner after mint runs, so I will tackle that next. Should be straightforward after last December’s advice.
                  #23333
                    I’ve added to your “two into one” thread, which may assist.
