Forumite Members › General Topics › Health and Well being › Ailments › I in hospital
- This topic has 60 replies, 18 voices, and was last updated 7 years, 5 months ago by
Bob Williams.
September 23, 2018 at 11:35 pm #26312
A bit bored sitting on the bed in hospitahospitalq after having heart attack
JohnSeptember 23, 2018 at 11:40 pm #26313Oh bloody hell! Hope you’re ok John
September 23, 2018 at 11:50 pm #26314John STAY bored until you get the OK to active duty as and when the doctors tell you. Anything I can do for you?
Hope you get back to normal soon.
Dave
September 24, 2018 at 3:56 am #26326Oh dear Jb. Just chill and relax untill your back on your feet. At least your fit enough to post so that’s a blessing.
September 24, 2018 at 6:37 am #26327Blimey John. I remember being in the same boat 7 years ago now, almost to the day. You’re feeling better than I did!
The after care is fantastic, as you’ll find out. My blood pressure and cholesterol level since is always described as perfect. I don’t think you smoke any more, but giving up the fags is the biggest thing anyone can do. It cut my chances of another by 50%.
September 24, 2018 at 7:13 am #26328I was shocked by your news and cannot say more than take full advantage of the care you get and follow any instructions and warnings you receive. Others have given you their advice distilled from their own situations.
I am sure we all wish you well for a speedy recovery followed by a long and constructive post scare life.
September 24, 2018 at 7:19 am #26330Take care John.
Hope all goes smoothly.
September 24, 2018 at 7:26 am #26331Have they decided how to treat you? Angioplasty etc?
As said by all, best of luck.
September 24, 2018 at 8:11 am #26332Good grief John!!! Get well soon and listen to the doctors and let the nurses do what they do best, which is taking care of you.
September 24, 2018 at 9:51 am #26333Just to add to Dave’s advice, after they have sorted you out, it is wise to cut down on the ‘sitting around’ just fiddling with PCs etc and exercise more — fast walking a couple of miles/day is a good low cost alternative to joining a gym.
If your area has good aftercare they will advise you on building up to this or alternative more suitable exercise options as well as strategies for losing weight. For example, no snacks plus cut out sugar completely, and do not eat breakfast, only water until midday two days/week — sounds horrible but is actually pretty easy to do.
September 24, 2018 at 10:46 am #26334Crikey John – yeah take it easy and get well soon mate!
September 24, 2018 at 11:46 am #26335All the best and get well soon.
September 24, 2018 at 12:41 pm #26337I found exercise and dieting to control weight a very intensely personal project. I found over the years that it was far easier to start trying and get nowhere than it was to succeed. However, for what it is worth since mid May I have lost over 3 stone, or about 19 Kg and considerably increased by walking as I am once more dealing with our daughter’s dogs. I am out of the house by about 06:15 most mornings and then spend somewhere between and hour and an hour and a half before breakfast doing between 2.5 and 3 miles. Sometimes this is against tight time scales so the pace is usually brisk. I have been using the Google Fit application for a while and today finally agreed to increase the daily target for exercise and heart points. To be honest I had regularly exceeded both old targets anyway. This schedule is repeated in the afternoon with other periods of variable level activity during the day
I also try to keep a log of the calories that I consume. We have not used sugar for a long time, do not buy shops cakes and other similar products and avoid such horrors as processed cereals, so our scope for sugar reduction is very limited. Breakfast is based on Crushed Oats, Oat Bran and Wheat bran, raisins and hot water to soak them together washed done with about 1.2 litres weak tea using skimmed milk 50% with water. After that I drink only water Lunch is usually a pretty frugal affair as is the evening meal with both containing, but not limited to a high proportion of fruit and vegetables.
I cut out all alcohol and pretty much all snacks since mid May. I would not cope with the no breakfast idea as the level of exercise combined with the need to be ready for early morning trips across country for appointments requires me to be capable at pretty much all times of the day.
I have found that the weight loss and exercise has had almost no impact on my blood pressure. I inherited high blood pressure from my mother and am keen not to end up with the effects that it wrought on her, vascular dementia. I check the pressure regularly though not on any sort of schedule, my tablets have been changed about quite a bit but I have dropped one due to the intestinal effects and its marginal impact on pressures, perhaps the exercise and weight loss marginally helped but I cannot be sure. What does help a great deal is trying to avoid sources of stress to which my pressure reacts unfavourably.
Smoking never entered my schedule and has never been part of my life so I had nothing to gain there, but for some it could well be the key and should always be the first action point. Some now dead relatives should have read the writing on the walls or air in their smoky rooms.
My BMI is now below 23 by a whisker or two though I would like to drive it a little lower.
However, do not rush into any none medically sanctioned action plan, walking and other activities can be low cost and very useful aids but only if you were too sedentary beforehand and if the plan is medically approved and practical. Not just sitting down can be sound advice, but remember that periods of activity should be edited with periods of less active time; again under guidance. Most areas have improved their guidance and support over recent years so you should heed what they say and offer. For me a gym would simply not be practical.
September 24, 2018 at 1:42 pm #26338A bit bored sitting on the bed in hospital after having heart attack
Wow ! – that was a shock – very sorry to hear that John.
Take care and get well soon.
September 24, 2018 at 2:16 pm #26339On a monile not used to it. last night while I had angegram rhey did the stents x3′ I being monitored and stuck on the bed. they give me loads a morphine last night now it wore off my back killing me it been a nighrmare to get my normal tabs all sorte now maybe home tomorrow o going for a heart scan soon
JohnSeptember 24, 2018 at 2:32 pm #26340I can and I am sure the rest of the gang can only hope that it all goes well. Do not rush out, but it sounds as though good progress is being made, long may that continue.
Good luck and better health
September 24, 2018 at 2:35 pm #26341It took me days to scrub off the marks from the heart monitors, it looked like I’d been attacked by a fleet of octopuses ?
Stents are wonderful things, I only had 1 though, usually you are home on the second day but they kept me in an extra day as my T count had been so high. They wanted to do a full ultrasound before they let me out and no-one was available.
Good news! Amazon tells me your doormat has been delivered to a neighbour ?
September 24, 2018 at 3:12 pm #26343Glad to hear that your stents went OK, take it easy for a while. You should get plenty of post-hospital advice before you leave and they will advise you what/when you should be doing things.
When I had the normal post-op aftercare the big thing they stressed even before exercise/diet/smoking etc was morale. Apparently one side-effect of a heart attack is that some people get kicked into deep depression – thoughts of mortality I guess. Building on that finding it could be a good time to stick some funnies on your pad and read some belly-laugh comedies,
September 24, 2018 at 3:13 pm #26344Wow John that the most casual way to announce a heart attack. Take it easy and hope your up and running soon.
September 24, 2018 at 3:43 pm #26347Good news that you’re sitting up in bed and letting us know!
All the best for the recovery.
