HP PC8044 power supply
Forumite Members General Topics Tech PC Talk HP PC8044 power supply
  • #22108
    LeonLeon
      @apollo
      Good evening,
      A farmer friend asked me to have a look at his dead PC this afternoon, its a hp pavilion slimline core i3.
      I determined that the psu had packed up (Probable the huge amounts of dust in it. Actually used his compressor to blow it out, just filthy) . The psu is labelled as HP PC8044.
      Would ebay be the best place to look for a replacement? Are they are specific to hp?
      Thanks in advance
      #22111
        IIRC it was Dell that used to have some proprietary PSUs. Could well be wrong there.
        I’d have a good look at the knackered one and if all is well get a mid-spec, 400W odd  branded job.
        #22112
        LeonLeon
          @apollo
          The size is different, its not an atx. There wiring is the same, I used a standard atx I have spare.
          I’ve just learnt from scan that they have small form factor psu now (Its been a while since I’ve Fixed a PC). I’m think it might be a sfx psu. but not 100% sure
          #22113
            Hi Leon
            It looks like your HP uses a standard TFX sized PSU but I could be wrong.
            TFX supplies are available new but if you want to be sure of compatibility referbished HP supplies are on ebay for about £24
            #22114
            LeonLeon
              @apollo
              I believe you are correct wheels of fire.
              I’d rather have a branded psu, I hate for it to go wrong soon after.
              I think TFX (think form factor) uses the same wiring as ATX and just the physical size of the unit that is different.
              #22115
              BorisBoris
                @boris
                I believe that the PSU you need is  HP part no. 504965-001
                (HP-D2201C0 -220W Power Supply Unit) ?
                You’ll have a job finding a new branded model of this 🙂
                #22123
                  It might be worth checking the PSU for any fuses that have blown or that could have had a contact issue while being bunged up with dust before you give up on the old one. However, do be careful about the capacitors that can hold a high charge for a long time.
                  #22128
                    You are also correct Leon (except that its THIN form factor ?) TFX is electrically the same as ATX.
                    #22131
                    LeonLeon
                      @apollo
                      oops. I did mean thin ?
                      I’m thinking either the
                      https://www.cclonline.com/product/216127/GT-300/Power-Supplies/GameMax-GT-300W-300W-TFX-80-Bronze-Power-Supply/PSU1315/
                      or
                      https://www.cclonline.com/product/213968/SS-300TFXL/Power-Supplies/SeaSonic-300TFXL-300W-80-Bronze-TFX-Power-Supply-OEM-/PSU1302/
                      Never heard of game max, does anyone have any experience with them?
                      I have looked at the old psu and can’t see any replaceable fused but do get a strong smell of burnt electrics
                      #22133
                        @Leon, with the aroma of electronics that have ‘let the internal smoke and burning smell escape’ that does sound like a terminal situation. The fuses to which I referred are sometimes inside the PSU metalwork case, hence my warning to be careful about capacitor charges. Are those small enough, the dimensions look quite large compared to the unit in my server.
                        #22135
                        LeonLeon
                          @apollo
                          @Richard, I have had it open, probably didn’t explain myself correctly. I am an electrician so opening one doesn’t ‘phase me’ ( little electrical joke there ?, sorry).
                          I have been and removed it from the tower, its sat on my desk now. 85mm x 65mm x 175mm.
                          Interestingly it only has the 24pin, 4 pin and 2 sata power leads
                          #22137
                            @Leon, no offence intended, I know little about people’s background and should assume less. If I stray onto potentially dangerous territory I always try to warn about the risks that might exist. I do not want someone to come suing me after the facts come to light.
                            #22142
                            LeonLeon
                              @apollo
                              @ Richard, none taken my friend. Always best edge on the side of caution.
