Honda Vulnerability
Forumite Members General Topics Tech Security Talk Honda Vulnerability
Viewing 3 posts - 1 through 3 (of 3 total)
  • #69760
      If you have a Honda it is possible that your car can be easily hacked.
      Gizmodo link
      The only way of mitigating this appears to be to keep your key fob in a Faraday Pouch.
      #69762
        You think that’s bad. Farmers have been complaining for years that tractors  & £500,000+ combine harvesters often use the same basic ignition key.
        #69765
          Ford had a problem a few years ago with people capturing the signal from the key fobs on keyless entry and go Fiestas. The solution was a motion activated key fob. Simple and works well. For most people. Because of the way I move on my crutches the motion sometimes isn’t vigorous enough to enable the key fob so I have to shake my pocket a bit. Can look a bit strange in the supermarket car park….
