Forumite Members › General Topics › Other Stuff › Headphone or dongle range
- This topic has 15 replies, 7 voices, and was last updated 7 years, 6 months ago by
The Duke.
August 21, 2018 at 11:17 pm #24993
I was going to use this thread but it seems dead.
Using my headphones when I go out the room (where the source is) they lose sound, then disconnect themselves.
Is it the wifi dongle (Mini USB CSR Bluetooth 4.0 Dongle Adapter) I have cheap wifi headphones and some not so cheap, both sets go off when I leave the room.
When I say cheap headphones they was £10, the same I think are now £24 (7dayshop)
if I purchase something like this would I be able to listen to music while s-itting down or do I need better headphones.
JohnAugust 22, 2018 at 2:13 am #24994It’s about 30 foot, but adding walls it’s probably more like 10 foot.
Iirc the latest standerds which I don’t think is that widely adopted. So you saoikd like you’re in the ball park of that the standard is capable off.
You’d know my bose head phones go further than my teotronics buds, but never tested how far bose go, but I know they cut out at around ten foot, where my buds do. I know this as desk to toilet is about 10 feet, as the crow flies, (via two walls), they go choppy some times when I visit the loo.
However there is a huge price difference. £16 vs £320. So if your happy with your sound, I’d say stick to what you have. You’ll probably need to invest a relative amount to gain an extra few feet. And a huge amount to go further.
For anything but serious music listening to, which I do little of, (though listening to the wall atm), my sub £20 set up is more than good enough. Though I do need two sets of the cheap ones, as I only get about 6 hours out of them, and I do more than 6h with buds on. So always have own on charge.
August 22, 2018 at 8:16 am #25005My daughter has some Panasonic cans that she is able to wear in several areas of the house when the source machine is upstairs she can come down to the kitchen and perhaps move a little more, a minimum of two or three walls and a diagonal of 30 feet plus. The walls are notorious Wi-Fi killers so the headphone signal must be pretty good. I suspect that is close to the limit for headphones. They are full cans, with rechargeable AAA batteries.
August 22, 2018 at 8:45 am #25007Thanks Duke & Richard
Maybe stick with what I have and pause the source when moving. At least I can go in the kitchen without loss.
It’s a shame as I listen to music a lot on the PC (especially now I am not trapped with the wire) but I loose it when doing physio, and that’s a time I would like to listen.
JohnAugust 22, 2018 at 9:34 am #25010What you need is a BlueTooth Repeater (assuming you do not have Wi-Fi headphones), but that will only add another 10-30 feet per Steve’s reply.
I have never wanted/needed one so I cannot recommend a make. If I were buying one, I’d get one from Amazon for easy return if it does not work!
August 22, 2018 at 9:48 am #25012Is the bluetoth dongle at the back of the PC – maybe affecting the range if it is in between a PC and a wall. Maybe worth connecting to a frnt USB slot (I know they are liable to get knokced there) or get a USB extension lead and extend the dongle from a rear usb port to a better location. The headphones themselves vary tremendously too. My taotronics and soundpeats will comfortably do 200 yards at my gym including through a set of thick double doors. My little hearing-aid style bud I use when walking will struggle at more than 15ft with line of sight.
August 22, 2018 at 10:58 am #25015BL it could be a difference in the receiver between Low Energy BlueTooth and the regular high energy flavour.
August 22, 2018 at 11:05 am #25016Well I found the above interesting ?
August 22, 2018 at 11:19 am #25017Oh it didn’t include the bit about repeaters and recomendations ?
August 22, 2018 at 12:06 pm #25018That is a good point, my daughter’s head phones are not BT but a semi stand-alone system gaining sound from a device but providing the point to point drive from the dedicated base station that also doubles as the charging point. I guess it is a matter of horses for courses. BT is much more limited, even before about 25 feet even on one level and with a wall or two it will likely fail.
August 22, 2018 at 10:02 pm #25035Thanks all for the info
Wheels the link talks classes good knows what class mine is in.
Blacklion it’s at the front of the computer, they go off in the loo too from the TV.
Another problem.
My Bluetooth dongle (CSR4.0) seemed to stop working in both computers. I purchased some new dongles.
Rig 1 (HP) works again with the new dongle, rig 2 (Lenovo) the light on the dongle flashes, it shows in setings/devices/bluetooth-printers-mouse, the headphones say pairing, but they don’t connect.
The headphones (2 sets) work in the HP and the TV, they just won’t connect to the Lenovo?
I never have both rigs (using dongles at the same time.
JohnAugust 22, 2018 at 11:58 pm #25041I found having a few pairs of BT ear phones connecting to different devices can end up with the cans connecting to the wrong devices, and some cans will push others off if you forget to turn one off.
So om my pc I have a dedicated pair of BT buds. But my phone does the major share of my listening, so that is what all my other sets connect to. I don’t connect a pair to two different devices that I know ill be near both regularly. Hope that makes sense, not sure I it does.
Basically a seperatepair of earphone per device. Give mine are cheap, it’s not a big issue to have a few pairs.
I also have a cheap pair of head phones that has a reviver stand, ment for PC or tv work. But the cussioning is so hard I can’t water them. Used them once (a prezzie). I should dig them out for my girl, she would probably use them on her mac. My lads already have decent wired sets.
August 23, 2018 at 1:48 am #25043John, you might be better off either copying the music to your phone, or streaming it from your computer to your phone. MediaMonkey will do it for free, and I’m pretty sure that the free version does volume normalisation too. If not, you can get the Gold Windows version through TrialPay, where you buy something from a choice of shops and get MediaMonkey as a gift.
https://www.mediamonkey.com/download/
That’s more likely to be the walls rather than the range. I’ve got a Bluetooth stereo in the garage, and if I go through the door into the house, the music stutters. On the garage side, the music’s perfect.
August 23, 2018 at 8:37 am #25061Thanks Duke & Tippon
I never use more than one source at a time so the headphone shouldn’t be confused. I wait till the rig is off, then turn on the TV dongle and the same headphones auto connect. When I come back to rig 1 I have to enable.
I have the music on my mobile, I can send it to the headphones, but don’t use it, I get confused when I take a call as I have to take the headphones off disconnect bluetooth (to release the phones) and take the call, it’s wrong off by then.
I just can’t understand why the Lenovo won’t connect to the headphones (or the headphones won’t connect to the Lenovo) there is a USB dongle in the Lenovo and it shows as working.
JohnAugust 23, 2018 at 10:34 am #25071Wheels the link talks classes good knows what class mine is in.
As a very rough generalisation, any Bluetooth appliance that is more than 5 years old is probably class 1 or 2. Normally such kit would be mains powered as batteries would only last a few hours. Typical of this would be very early rechargeable mice, drawing pads. or toys. Imo most such items are now wifi instead as the range/energy equation favours that choice.
Recent small kit e.g. earbuds etc are almost certainly BLE (class 3).
August 23, 2018 at 4:40 pm #25079I think all my are BT low power. Which I think means it the newer standard. My bose cans works all over the house. So tested to probably 40 feet through a few walls. My cheaper buds, which are also new (ish) they give battery feed back to devices etc.. Probably get 10 at best through walls.
I don’t mind though, that works for my uses.
