HDMI and Display Port.
Forumite Members General Topics Tech Gaming HDMI and Display Port.
Viewing 1 post (of 1 total)
  • #69945
      I never really gave it a lot of thought the difference between HDMI and DP. But I recently got a new monitor and getting it to work properly eluded me until I had the brainwave to try display port.
      Yep, with DP my monitor now works as it should.
      Just to see the pixels fully active and the contributing colors because of that and eye strain completely disappear.
      Man if you are using HDMI get rid of it or at least try DP.
      I’m also of the opinion that nowadays you should only change your GFX drivers if you have to.
      if it ain’t broke don’t fix it. Like with Bios flashing.
