Forumite Members › Forumite News & Feedback › Forumite Updates › Forumite Updates
- This topic has 26 replies, 8 voices, and was last updated 5 years ago by
RSB.
December 29, 2020 at 8:49 am #64983
Firstly, I am sat at home miserable, with no cups of tea due to no water. For some reason where I am, when someone turns there water off it also turns off 4 other surrounding houses. I will be knocking on doors soon to find out who although two houses are empty so that may difficult.
Anyhow. I will be doing some much-needed maintenance, updates & fixes to the site other the next few days so things may or may not work until I am done. No major changes though.
P.s. I do have 2 bottles of real ale left if I get thirsty.
January 18, 2021 at 8:25 am #66489All hail the ale 😉
January 23, 2021 at 5:27 am #66708Some changes being made. Firstly I am going to be stripping back as much as possible of the site and try and make it is less resource hungry. Once this is done I am moving the site to a new server. This is due to the noticeable drop in visitors and obviously costs. I am cutting back on everything I can. I am looking to replace my greedy, power munching PC’s and laptops with something like PI 4’s and lesser models for lighter network stuff.
Anyhow, I will be dealing with this site this weekend so expect some issues and down time.
January 23, 2021 at 7:31 am #66711What server specs do you need?
January 23, 2021 at 7:57 am #66713Its not really about server specs and donations and costs although all three are a minor part of it. I want to just strip it back now so less management is needed. I am trying to get all my ducks in a row so everything going forward is cheaper and just easier.
January 25, 2021 at 8:46 am #66846As you can see, just enough to get the forum functioning. I’ll do the rest when I have had some sleep.
January 25, 2021 at 8:56 am #66847Looking good Lee.
January 25, 2021 at 7:29 pm #66858I like it.
Easy on the eyes and nice and clear.
Nice one Lee.
January 25, 2021 at 9:28 pm #66860I like the look.
Looks like safe mode from yesteryear, on windows that is, I’ve not looked at Android yet. 🙂
January 25, 2021 at 9:44 pm #66861I’ll be finishing most of it off tonight. The site will have mostly the same things as before but in a toned down and much less resource hungry.
Much easier to work on as well with the dark colour.
January 26, 2021 at 12:44 pm #66892It would be nice to see the final hardware set up you go for with a photo. 🙂
January 26, 2021 at 11:19 pm #66906I dont have any hardware, the site is not being hosted from under the stairs. 🙂 I guess I am missing something.
January 27, 2021 at 11:22 am #66940I fought you was use in a Raspberry pi 4 or samink (cockney= something).
I could just see it all running out of a shoe box or samink. 🙂
February 1, 2021 at 4:55 pm #67046I fought you was use in a Raspberry pi 4 or samink (cockney= something). I could just see it all running out of a shoe box or samink. 🙂
Sorry, forgot to reply. I plan to reply then 5 minutes my head drifts off 🙂
Anyhow, my plan is to get below £1 per day electric usage. Pi’s are the only way I can achieve this. I am going to use a few pi’s around the house to achieve this. But I am also going to build a special pi system into my own custom-designed case with customised components. Something really nice and polished that can serve as everything. That is everyday pc, media centre and server, retro gaming, hi-fi, Freeview, DVD player and so on.
February 2, 2021 at 9:33 am #67053That would be nice to see, if you feel up to it.
I can almost see the set up now. Hmm.
February 2, 2021 at 9:38 am #67054Yes, I’m up to it. Need to get the gear first and lay it out on some cardboard and work out where all the holes are going to be, a template of sorts as it will involve some custom toughened glass.
February 2, 2021 at 9:42 am #67057Cool. Show off.
February 2, 2021 at 9:46 am #67058🙂 Saying that I may consider building one out of some plush wood first. Its should be cheapish to do as I will be using mostly Chinese imported stuff where I can.
February 2, 2021 at 10:11 pm #67064Have you got your Pi’s Lee?
February 3, 2021 at 7:02 am #67065Have you got your Pi’s Lee?
Cheers Mark, I have sent a PM back.
@planeman Got me started on this route by kindly giving me a PI ZERO W. At the moment, it is making a nice little media server and just simply works.Another thing I will be saying goodbye to is my fridge/freezers. That should be easy being winter but hopefully, by summer I will have adjusted to not having them. I will just buy stuff on the day it’s needed plus I have a cold cellar.
