• This topic has 43 replies, 12 voices, and was last updated 9 years ago by RSBRSB.
Viewing 20 posts - 1 through 20 (of 44 total)
  • #4350
      As you can see in the Index area “Here” the forums are slimmer but in the latest replies “Here” the forum is full width with no info down the side. How many would have issues with the latest replies looking like the index with info down the side? This is desktop only.
      These changes will give me a bit more flexibility. I will also be working at getting the side info slimmer and stretch the forum.
      #4352
        I rarely use the DT site, but prefer the clean look of Number 2. To me the info in that side bar is  usless the wait is. If it had my inbox counter and some nav buttons like recent, and say an evolving list of my regular forums I frequent. Then id find it useful.
        However I don’t know what your plans are for that box, so it may be awesome and we just dont know it.
        On mobile I always miss PMs I find the messages Inbox tab is too far down the list, and I rarely scroll that for Down, so I’d like ‘recent’ and ‘inbox’ to be the top two options on the hamburger menu.
        #4353
          Not looking for other sugestions, just answers to this question for now 🙂 :wacko:
          #4388
            New version looks great on the desktop Lee, but I have a 24″ monitor so it would. Bearing in mind that I have poor sight now, I would prefer that version as OK. But I think someone with a smaller monitor needs to answer. For me, it’s fine.
            #4389
              The text size is same so should not pose a problem.
              #4398
                Not bothered either way.
                As long as it works I’m happy.
                IMO do what’s easier for you to deal with.
                #4399
                  Ive set the forum Index to full page more or less and looks ok. Just need to sort mobile out for sgb.
                  #4402
                    Also on a 24″ monitor, but I much prefer the wider version. The wider layout puts more on the screen.
                    #4416
                    Robin LongRobin Long
                      @knightmare007
                      Forumite Points: 12
                      I prefer 1 but tbh I could live with 2 no problem
                      Cheers Knight,
                      RIP Spike09 Your Missed
                      If I'm not here, I'm there.
                      #4421
                        For me, version 2.
                        Going off topic for this thread, the reply visible when NOT logged in to demand login and return to same place would be very helpful. I stay logged off unless I want to respond. Of course I may be the odd one out as usual.
                        #4441
                          I wasn’t making a suggestion, I was highlighting why the side bloat is of little use atm in its current form.
                          Looks alot cleaner without it. only if you was to add something that is useful to the majority would it be worth adding back it. Thou tbh I don’t really care, as I don’t normally use the DT version.<span style=”font-size: 16px;”> </span>
                          #4478
                            Liking the blue bar between posts – makes the reply/quote/edit easier to see, and it is brighter than the grey. :good:
                            Post number, while not very important, would be easier to read in black than yellow.
                            Thanks for all your work over the last few days, Lee.:-)?
                            #4480
                              Yep, it’s getting there now. Few more adjustments now and I’ll be happy and can start thinking about coaksing a few more mebembers this way. Thats the plan anyhow, can’t have people coming to tip. 😉
                              #4483
                                Either works fine using Pale Moon, so what ever is easiest for you.
                                OT. The Forumite banner at the top of the page (Home/Forums etc) became too deep & covered the top of the topic for several days, if the browser wasn’t the full screen width. Anyway, whatever you did has corrected it. I seem to detest having anything in full screen mode. :scratch:
                                Also shows I read the new posts every day even though I don’t sign in.
                                #4489
                                doctoryorkiedoctoryorkie
                                  @doctoryorkie
                                  This. :good:
                                  Server N54L 8GB SSD 6x Spinners HD6450
                                  #4491
                                    Looks good on mobile to, all these little changes.
                                    #4507
                                      @RSB, Big improvements. All way above my head, but improving significantly day by day right now.
                                      #4535
                                        Looking good, Lee. You’re working well: these are the kind of improvements that we would not have realised as improving the site, but they do.
                                        Many Thanks, good work. :good: :yahoo:
                                        #4550
                                          I don’t know if it’s because my laptop’s got a fairly low resolution (1366 x 768), but there’s not much difference between the two comparisons in the first post here
                                          #4551
                                            Ive only just made them the same “more or less” :yes:
