Flickering screen
Forumite Members General Topics Tech PC Talk Flickering screen
  • #28855
    JukeboxJukebox
      @jukebox
      I recently treated myself to a new Philips monitor which has HDMI and VGA inputs. One of my preferred photo editors is Photoscape 3.7 as it is quite easy to use and has a good clone tool. However when in edit mode the screen starts to flicker after a minute or two which gradually gets worse and makes the thing unusable. If I switch to ‘Viewer’ mode the flickering stops immediately but starts again when switching back to edit. This occurs whether I use the HDMI or VGA inputs and it doesn’t happen with the old monitor. It doesn’t do it on any other program I’ve tried nor if I use the later PhotoscapeX (which unfortunately doesn’t have a clone tool unless you pay for the professional version). I’ve tried varying the refresh rate but that didn’t help. Any ideas?
      #28858
        You could try Philips troubleshooter, and check all monitor cable connections are tight. If these do not work then RTM asap.
        #28879
          Hmm there is a small chance that photo 3.7 is changing the refresh rate.
          Install fraps to finfd out.
          #28916
          JukeboxJukebox
            @jukebox
            Sorted! Changing the Gamma setting on the monitor from 2.2 to 2.4 removed the problem. Bit of a mystery!
            Thank you both for your suggestions.
