Everything's underlined!!
Forumite Members General Topics Tech Windows Talk Everything's underlined!!
  • #11685
      In the last 24hrs or so all of my folder names and their contents appear underlined on screen and I can’t seem to get rid of it. How do I get them back to their old ways – no underlining.
      I attach a screen shot of the problem.
      Many thanks,  Dave
      #11687
        You somehow changed your folder options. Assuming you have Windows 10, open Explorer, select the view tab, go to the Options tab (far right), change folder & search options, there is an option to click items. Use the ‘doubleclick’ to open option not the Single click one. Or if you like the single click option then change it to underline icons only when they are pointed at.
        Long time since I used 7, but open Explorer and somewhere on the menu bar is a folder option, then proceed as above.
        #11688
        JukeboxJukebox
          @jukebox
          Looks like you’re in ‘single click’ mode. In File explorer go into File Options and in the ‘General’ tab – ‘Click Items as Follows’ select ‘Double Click to Open an Item’.
          Edit – Sorry EdP you must have replied whilst I was typing!
          #11691
            Sorted!!  Many thanks to you all.
            Dave
