Viewing 20 posts - 1 through 20 (of 22 total)
  • #22618
      I had Driver Pack on DVD some years ago (off Dave Rice) I have tried to use it but now get errors, it asks if I want to use online.
      Online scans my rig then I get errors, server can not be found, we’re working on it.
      Also my F-Secure blocks the sight as dangerous
      Anyone got the latest version I could borrow, or even is Driver Pack stilll going
      I have these conflicts on Win 7
      #22628
        Assuming this is an Intel PC try Intel directly https://downloadcenter.intel.com/
        #22629
          Thanks Dave it’s a Lenovo E50-00 in the past I had drivers off Lenovo but can no longer find them.
          I procceded on your link, but kept getting met with
          Oops, something went wrong while trying to scan. Please try again, or see our FAQs for help.
          I turned off my security and still the same. I looked on FAQs but nothing on there about the message.
          #22637
          The VFM AddictThe VFM Addict
            @thevfmaddict
            The page you need, John, is Lenovo EOL support.    Its here.    Just select Desktops, Thinkcentre E Series and then E50.
            _______________________________________________________________________________________
            During the Covid-19 Epidemic I will be wearing a mask and goggles while posting so that if I become infected I won't spread it to you.
            #22638
              I use Snappy Driver Installer nower days.
              Its free and it rocks.
              Ive just rescued dell lenovo 200.
              The driver and app D/L it found was just shy of 1GB.
              #22639
                Thanks for that – new one on me – downloading now.
                #22640
                  Thanks VFM I will have a look.
                  Keith I meet even dl (for ron) Snappy Driver, blacklion seems happy with it.
                  #22651
                    I went on Lenovo, it led me too a long list of drivers/software, but nothing I need. It seems most are for XP Vista andso on not much for 32bit OS. I did find Lenovo Rescue Centre for Windows 7 I am gonna try that.
                    Snappy Driver has been a nightmare, I now have Opera – Facebook Icon – Web Companion) amongs others ( I never wanted)
                    When I tried to install SDI Lite it dl a file, I have nothing to open it with, I downloaded and installed Bit torrent and tried to download SDI Full, it kept saying Bit Torrent is open but not working.
                    I got there in the end, don’t know how long I will be at it, so far 3% of 15.5GB downloaded it’s going to fit on a DVD, but still, there you goo.
                    #22655
                      38% only 2hrs to go
                      #22659
                      KumagoroKumagoro
                        @cobrakai
                        I don’t know how you managed to get all that other stuff on to your machine. I have been using SDI for ages and have seen nothing like that.
                        Where did you download it from.
                        The download is a zip and you can run it off a USB stick as there is no installation…
                        https://sdi-tool.org/download/
                        #22668
                          Kumagoro
                          I had it off the same link as yours I hit SDI Full / Download while’st sorting it downed the others. I think it want to use Opera not FF. It wasn’t a zip it dl a folder SDI_RUS.
                          I am now copying to USB and hope after all that I can sort out the conflicts
                          #22669
                            Thinking about it, the other stuff may have come down with bit torrent install.
                            #22671
                              All sorted (after using Snappy Driver) no more conflicts.
                              #22681
                                @thevfmaddict
                                Glad to hear you are sorted, John.  But just a tip for the future.  On that Lenovo page I gave you after you get to the E50 page the second drop down menu allows you to choose your OpSys – for example, Win7 32 bit or Win7 64bit, Win8, Win 10, etc.    Are you sure you selected the correct OpSys because you should not have got any XP only drivers on the list that resulted.
                                #22683
                                  Thanks VFM
                                  I had another look, it no longer offers E50 only E30.
                                  I then clicked (at the top) Support and entered the serial number. It came up with Solution Centre (I have) and realtek lan (I have the rest was 64bit only, I am using a 32bit 7 (the original I think was 64bit)
                                  To be sure I need a Windows 7 64bit.
                                  #22685
                                    Thanks VFM
                                    I had another look and it’s no longer offering E50, I put the serial number in (on support link at to p of your page)
                                    It only offered Solution Centre & Lan (I have those) then I realised, they offer 64bit for mine, originally it was 64bit, I am using a 32bit Win 7. the 64bit is now tied to Windows 10.
                                    #22688
                                      @thevfmaddict
                                      It is still there, John.  Remember its a Thinkcentre E Series not a Lenovo E Series,    That’s why I put it in bold when I first gave you the link.   If you choose Lenovo E Series you only get E30.    BTW once you get to the E50 page if you go to the top you can get the Hardware Manual for your desktop if you don’t already have one its worth having.
                                      #22702
                                        Thanks VFM
                                        I (just) entered my details, once entered if you scroll down is the list I mentioned for XP Vista etc
                                        I am not sure what it is ThinkCentre Think Station all it has on it is Lenovo even after putting in the serial on Lenovo web it only says Lenovo.
                                        All the conflicts are gone (snappy driver) for now.
                                        #22707
                                          The Lenova laptop was the IBM Thinkpad originally, and they ran the Thinkpad name in parallel for a couple of years iirc..
                                          #22708
                                            You saying that Ed, sometime ago I heard Lenovo was IBM in disguise.
                                            Maybe you said it? in another life (MM)
