Donated PC case
Forumite Members General Topics Tech PC Talk Donated PC case
Viewing 3 posts - 1 through 3 (of 3 total)
  • #167
      I was given a pc due to my ageing PC’S, I think I mentioned it in the linux thread not so long ago. Any how what grabbed my attention of this pc  was the quality of the case, Its built like a tank, Its great  :yahoo: weighs a bit but you can tell it was built back in it’s day to last. Gigabyte summo 4112.
      #177
        Back in 1997ish, when I was building PCs, we used to use a cheapish case, and a more expensive one. Right now I don’t recall the name, but I once came across a “Gateway” which obviously used their case. They were very well built, and the power supply units NEVER failed. I won a few when they were replaced after a year or two, and I passed my final one on to my son just before I put this Shuttle together. Some of the rubbish which followed it barely deserves mention. We started to get a cheapo, and one of the first I put together had a “hot resistor” smell at switch on. One or two failed to fire up their PSUs  However it was a maybe a year before they started failing in earnest; PSU over-voltage, followed by dead hard drive, and sometimes other stuff. So, the customer needed a new PSU and HDD, plus all his (not backed up of course) data. This overran into the era of the Fujitsu HDDs that screwed themselves up, and when a PC came in for a replacement HDD, but still working PSU, I had to diplomatically advice a new PSU would be a worthwhile addition. (or it will go bang next week, and you will need another HDD)!
        #178
          I have some old Dell machines here (Pentium 200 @ 233, jumper overclocking was so easy) and they are like tanks.
          One is my bedside table and they all came out of the old South Wales Echo building maybe 15 years ago when their systems were updated and it was cheaper to give them away than scrap them.
          One was in the print room and is battered and covered in ink but it still works.
          Older isn’t always better but sometimes it is.
