Win 10 Cumulative Update KB4013429 (OS Build 14393.953)
Forumite Members General Topics Tech Windows Talk Win 10 Cumulative Update KB4013429 (OS Build 14393.953)
  • #5182
    BorisBoris
      @boris
      Mine https://support.microsoft.com/en-gb/help/4013429 seems to have just installed OK on my test (ancient) PC – has anyone else had any problems with it ?
      #5183
      BorisBoris
        @boris
        Just noticed that this “The Windows 10 Creators Update is on its way” has appeared under Updates
        #5200
        Alan WoodAlan Wood
          @alanrwood
          Updated 10 machines without any problems. I expected more updates considering we were to get 2 months of them this time.
          #5206
            It took twelve minutes for my first machine, others will follow on. ‘Preparing’ took about half the time. The next couple will be slower.
            #5210
              Wow, even my 2008 Dell Vostro 1500 only took the same time to complete the process.
              #5225
                Took 40 minutes on my Asus S200 (3rd Gen I3, 4GB, SSD) – I had just done a “Disk Clean Up” and wonder if wiping out all the update files made it take so long. For me the “Preparing to Configure” was 25 minutes!
                #5465
                BorisBoris
                  @boris
                  Yet another one just installed – KB4015438 (OS Build 14393.969)
                  #5466
                    I didn’t time it but my normally scorching i3 took a lot longer than normal both before and after the reboot. However a lot of that is probably down to the malicious software scan that was part of the bundle.
                    Not seen KB4015438 yet, but have had the “Windows 10 Creators Update is coming soon” notice.
                    #5469
                      Do these updates install on their own if you leave your pc on 24/7 as ive not seen an update since anniversary, and that may of been as my pcs was all powered down as I was in EU at the time.
                      #5470
                        Yes they install on their own. You have a problem if you haven’t had any since Anniversary.
                        #5479
                          I’ll have to look what I’m running in a bit.
                          Update. Just checked and I’m up to date. I have the one mentioned above plus a steady stream of others.
