Copy and paste from emails
Forumite Members General Topics Tech Linux Talk Copy and paste from emails
  • #36100
      This may not be specific to linux, but since I use Mint (19.2), I will ask here.
      I am a member of various email lists, and if some useful info is included in an email, I (used to) select the text of interest, ctrl-C, open Writer, then CTRL-V to get it into a document. Recently, however, it has not worked. Other than doing a screen shot, then using an OCR prog, does anybody have a solution to this?
      Cheers, Les.
      #36103
        Is it Thunderbird? Just tried it in TB in W10 and it works just fine.
        #36105
          Again on Thunderbird on W10 – I use that a fair bit, usually on Customer service emails – I copy and paste their promises from their  emails and let them know it hasn’t happened!!
          Last tried a couple of days ago. No problem. Works OK today too.
          #36107
            You won’t believe this. I went to the same email which would not copy two days ago, or this morning before I posted the above.
            It works for you, but it does not work for me, lateral thinking time.
            For the FIRST TIME EVER, I opened Libre Office’s “Impress” as I guess it is different to Writer, but capable of holding text (maybe). I selected just the first line of the mail **, ctrl-C then in the Impress box, ctrl-V. There it was.
            I deleted it, selected ALL the wanted email text, and again transferred it to Impress, and there it was.
            Now for more lateral thinking. Open Writer, ctrl-V, and there it is again.
            I still don’t know if it is “just working” once more by coincidence, or if opening Impress was relevant. No doubt I will find out in due course, but for now it is working.
            ** The reason I only tried one line is that there have been occasions when copying a whole article would not work, but a paragraph might, but sometimes only sentence by sentence.
            Still time to edit.  I saved my Writer document and closed it. I then returned to the Impress item, selected all except the first line (to ensure the original not in memory still), opened Writer, ctrl-V, and NOTHING happened. More to think about, not sure any of it makes sense.
            #36113
              Random email TBird under Ubuntu, copy &paste of multiple lines to Libre Office worked without issue.
              One quirk I have noticed is that Linux sometimes clears the copy cache if you have closed the originating document. The latter does not seem consistent but I have never investigated the parameters.
              #36115
                Edp, I have not tried any more yet, but do have some more emailed stuff to copy and save.
                I learned about the loss of copied data if you close the originating source a long time ago. I do a lot of copying and pasting when I create certain drawings, so I have an almost automatic routine of ctrl-c    alt-tab   ctrl-V   alt-tab to move back and forth when just copying individual elements from drawing to drawing.
                #36116
                  Rather than ctrl-c, does a right click on the selection bring up a context menu with copy on it?
                  #36153
                    Dave, yes, tried that as well.  In Terminal, only rt click – menu works. For years I only knew of that, before I discovered ctrl-(loads of things). I have not got my printer properly installed (should use the HP-Linux drivers), just the default stuff. certain items (pdfs opened in the default prog I think) will not bring up printer. However I find ctrl-p allows me simple printing. Similarly because not HP drivers, my scanner is not recognised by PC, so I go in via Firefox, 192.168.  etc. and use the PSC’s inbuilt stuff.
                    Every year I learn at least one new dodge!
                    I have some more stuff to copy/paste later if time allows, so I will do more experimenting.
                    Cheers, Les.
                    #36154
                      In a terminal use SHIFT Ctl V to paste and SHIFT Ctl C to copy.
                      #36164
                        Edp, if I can remember that, it will be another instruction learned this year!
                        Cheers, Les.
                        #36269
                          Try using a clipboard manager (https://www.tecmint.com/best-clipboard-managers-for-linux/ for a selection), that way, you can see what exactly has been copied.
