Forumite Members General Topics Tech Software Talk column width
  • #35318
    oldtimeroldtimer
      @oldtimer
      Just to show I am up to date I am still using Office 1997.?  It does most of what I need so why change?
      Well, it  does not read docx files and does not run under Linux. So I loaded Libre Office to download docx then save them as doc. files for Office 1997. It is a bit of a pain but I only produce/read docx files about 5 times a year.
      I could  use Libre office full time and that was the plan until I discovered that in the spreadsheet, col. width is specified in cm but in Excell it is specified in characters which seems to me to be much more sensible in an application that uses numbers.
      So does anyone know if it is possible to change the basis in Libre Office to the same as in Excell.
      Its easy when you know how
      #35319
        Hi, Not really certain what you mean – you can increase the column width in both LO and Excel simply by placing the mouse pointer on the join between two columns and then move the desired column width to the R or to the L as necessary.
        I am assuming that this is not quite what you are after but having looked at both s/sheets I cannot find anywhere where it specifies column width either in No. of Characters or in cm/ins.
        #35324
          Have you tried downloading the compatabillity pack for MS Word ? Microsoft says it only works on Office 2003 and above but I have installed it on Word 2000 and it lets me work with docx files just fine. I would be interested to find out how far back the support really goes ?
          #35328
            I was using 97 Pro myself until I changed to OpenOffice. I downloaded the compatibility pack when I originally installed OO, had no problems at all saving in either format. Sometimes there is a warning about saving in original format when converting a saved document, but I have always ignored that and never suffered any loss. I would think that Libre Office will have the same pack.
            #35340
            oldtimeroldtimer
              @oldtimer
              Pehaps I did not express mysf properly.
              Re Excel Col Width.  Right click on the top of any column then select Column Width.  Up pops a box with a number.  This refers to the column width.  On an unmodified spreadsheet this states 8.43 which I presume is the default width. It is perfectly wide enough for 8 characters plus a decimal point and I have always assumed it refers to characters.  Do the same in LO and up pops a box which states 2.6cm.  It does not seem to be as user friendly but in time I could get used to it if there is no alternative.
              Re Word.  I had a major “melt down” a while back which wiped out the OS and the compatibility update files.  Sadly MS does not have the old files and although I have tried the newer files they say there is no software on the PC that is compatible with the compatibility updates.  However I might have struck lucky on this because I have an old machine which had been updated and I think it might still have the upgrade file on it.
              Fingers crossed!
              #35341
              oldtimeroldtimer
                @oldtimer
                Seems to have worked!
                #35342
                  Nice to know ?
                  #35343
                    Interestingly Windows update seems to think I have Office 2007 installed because it keeps sending me updates and bug fixes for it but I really do only have Word 2000 ?
                    #35350
                      ….but I really do only have Word 2000 ?
                      Maybe the “backwards compatibility” they espouse, qualifies you with regards to updates, ie, anything to update W2007 gets sent to users of 2000!!
                      #35375
                      TCBarrettTCBarrett
                        @tcbarrett
                        Just a random thing, as I know this is a tinkering community. If you change the .docx suffix to .zip, and then unzip it, you will find all the somewhat-humanly-readable XML files that comprise your document…
                        Family. Coffee. CrossFit. WordPress. にほんご。
                        #35400
                        oldtimeroldtimer
                          @oldtimer
                          Interesting.  Something for one of those days when I am looking for something experimental to do.??
