Forumite Members › General Topics › Tech › Security Talk › Chrome and Firefox Phishing
- This topic has 10 replies, 5 voices, and was last updated 8 years, 11 months ago by
Richard.
April 18, 2017 at 3:22 am #6359
A new phishing attack has been identified that affects Chrome and Firefox. There’s a manual fix for Firefox (including Tor), and Chrome will be fixed in a new update.
https://www.wordfence.com/blog/2017/04/chrome-firefox-unicode-phishing/
April 18, 2017 at 7:29 am #6362Thank you Tippon; warning, be careful how you search in Firefox . If you do it the wrong way you will not find the entry – I missed it the first time.
All corrected now, so thank you.
April 18, 2017 at 11:52 am #6370Many thanks Tippon, sorted that. Addition to Richard’s warning: mistake can be made if you do not type “about:config” in the LOCATION bar. (the bar directly underneath the Firefox tab.)
I picked that up by reading your comment Richard, which made me think, thanks.
I'm out.April 18, 2017 at 2:42 pm #6377+1. :good:
Server N54L 8GB SSD 6x Spinners HD6450April 18, 2017 at 4:58 pm #6388Apparently the problem has been splashing about in the mud for years, perhaps as far back as 2005 without anyone taking action.
April 18, 2017 at 5:22 pm #6391Apparently the problem has been splashing about in the mud for years, perhaps as far back as 2005 without anyone taking action.
Well, we just did Richard! :good: :yahoo:
I'm out.April 18, 2017 at 5:43 pm #6392Apparently the problem has been splashing about in the mud for years, perhaps as far back as 2005 without anyone taking action.
I meant to put in place a fix, though apparently IE is not affected, or so I am told. The problem sort of comes with stop gaps adopted without thinking them through at the technical level, in spite of several past attempts to start a solution.
Edited typos.
April 18, 2017 at 6:28 pm #6400Apparently the problem has been splashing about in the mud for years, perhaps as far back as 2005 without anyone taking action.
I meant to put in place a fix, though apparently IE is not affected, or so I am told. The problem sort of comes with stop gaps adopted without thinking them through at the technical level, in spite of several past attempts to start a solution. Edited typos.
Unless things have changed IE is completely vulnerable. I’m not certain about Edge as I do not have a Phishing example to use.
April 18, 2017 at 9:19 pm #6407April 18, 2017 at 9:52 pm #6411It will not work in Edge because the certificate is forged.
April 19, 2017 at 8:40 am #6422Apparently the problem has been splashing about in the mud for years, perhaps as far back as 2005 without anyone taking action.
Unless things have changed IE is completely vulnerable. I’m not certain about Edge as I do not have a Phishing example to use. link
I do not usually use IE, but I tried it this morning and the response was to not show the spoofed result but to show the address in garbled characters, just as the modified Firefox does. This will not stop numpties but should give others fair warning. I cannot be bothered to try Edge as I find it too slow and hard to figure out what Edge is doing, besides I have to take someone to hospital shortly.
