Cheap wifi cards?
Forumite Members General Topics Tech PC Talk Cheap wifi cards?
Viewing 16 posts - 1 through 16 (of 16 total)
  • #25937
      Does anyone have any recommendations for a cheap wireless ac card please? I’m looking for either PCI or PCI Express x1.
      I’ve got my computer linked through a USB card now, but every so often everything slows down, as if the USB bus is saturated while I’m transferring files. I also want to put one in my media server so that it can move out of the living room.
      ( P.S. Dave – I eventually got around to putting a wireless access point in the attic to test the signal strength, and it didn’t make much difference. Something in either the walls or ceilings is killing the wifi 🙁 )
      #25938
        Unless you know the signal is good, I prefer ones with an external antenna as the back of a PC is usually the worst place.
        Something like this
        #25940
          I too also suffer from walls and quite possibly ceilings that are about Wi Fi hostile as possible. I have put in three APs and some Powerline equipment to overcome the issue. Wi Fi is almost limited to the room with the AP. My latest router claims to be ‘very powerful’  yet its coverage really only extends to one or two adjacent rooms. I am reluctant to try the expensive Ubiquiti, though I noted that the preference is to install it below, rather than above the ceiling. Some modern materials may include foil for improved thermal performance, other items may include materials with similar impacts.
          #25941
            I’m quite willing to loan anyone the test kit (UAP 300N) for the price of the postage. No need to power it off the mains, it has a battery pack and a PoE adapter and a long patch lead. It weighs very little and a bit of blue tack usually holds it in place long enough if there’s no one to hold it up in roughly the right place. Often I’ll just place it on the top of a step ladder.
            All you do is fire it up, wait for the light to go steady green and use your smart phone (or laptop) with WiFi Analyzer to look at the signal strength around the building. We reckon anything in mid yellow (-75 db or less) is fine for general use.
            #25943
              Unless you know the signal is good, I prefer ones with an external antenna as the back of a PC is usually the worst place. Something like this
              Thanks Dave 🙂
              I was a bit confused looking at these, as I wasn’t sure if they were just PCIe adaptors, or if they had the card too. My knowledge has basically disappeared over the last few years.
              #25946
                Some have the WiFi circuitry on a soldered on chip, this is the most common. Some, like that Asus, have a laptop adaptor in a socket. Same horse different jockey.
                #25953
                  Wow you are very trusting and generous Dave, but I do not feel able in all conscience feel able to accept. Still the other part of your comment gave some good advice about trying to plot signal strength. Perhaps that way I can find the key reasons of the building murdering WiFi signals over the next couple of weeks.
                  #25962
                    Sorry to ask another question, but do you know why it’s got a USB connector? I would have thought that everything went through the PCIe slot?
                    #25965
                      It’s related to the Bluetooth not the WiFi.
                      Coincidentally, the card on there is the same one that Blacklion has put in his new Elitebook.
                      #26072
                        Thanks Dave 🙂
                        #26101
                          If you can wait until weekend, I’m not sure if I still have one or two. If one, you’re out of luck since it’s my emergency backup in case anything goes wrong with my switch. If I still have two, you can have one. But I need time to search.
                          #26116
                            That would be brilliant Dan, thanks 🙂
                            If it’s there, let me know what you want for it, and for postage ?
                            #26156
                              If I have a spare, it’s yours for free. I’ll  check on Saturday. Even if I can find it, I need to make sure I can find the antennas, too. That’s probably less of a problem, though, I’m sure they are easily and cheaply replaced.
                              #26168
                                Thanks Dan 🙂
                                #26236
                                  PM sent.
                                  #26244
                                    Dave, I have been trying Wifi Analyser as you suggested. It is quite interesting, though the results are a bit of a surprise.
