Car Radio MP3 Bluetooth SD USB Aux
Forumite Members General Topics Other Stuff Car Radio MP3 Bluetooth SD USB Aux
Viewing 20 posts - 1 through 20 (of 23 total)
  • #5546
      I purchased on of these last year it’s not been too good. The bluetooth doesn’t work-it did work twice since I had it (as in it did then it didn’t then it did, now it doesn’t)
      Folders don’t show in a list. It makes it’s own track listings and seems to throw mine out. ie: I have 10 folders with track 1-20. It shows a list of 1-100
      Maybe they are all like this?
      Can anyone recommend a good one, at a cheap price with a detachable front panel.  There is a few on Amazon around £15-£35 but which ones are good ones?
      #5555
        I use one of these
        Anker SoundSync Drive Bluetooth car handsfree receiver, for cars with AUX input (3.5mm) compatible with iPhone, Samsung, LG, HTC and all other Bluetoo https://www.amazon.co.uk/dp/B0177T3OEU/ref=cm_sw_r_other_apap_ES8xm71KKZsTG
        #5557
          looks interesting Duke
          I will give it a go
          #5558
            Here is a quick youtube video demoing/reviewing it. It’d not a full head unit replace like you asked for, but does a similar (ish) job.
            The end result is you can play media and take called via your car stereo speakers.
            Ive only skimmed the video. I’m out atm.
            #5564
              Thanks for the link Duke
              It doesn’t recommend if you don’t have bluetooth. In theory that’s my problem the radio doesn’t show/sync bluetooth. My mobile is paired with the radio but it will no longer sinc, so the anker won’t sinc.
              when I first had a look I thought it connected to the radio via USB, the USB and jack seem to be output (from mobile) only.
              Thanks for the suggestion, maybe not, back to the drawing board.
              #5565
                Regarding the folder display, my current (Pioneer) unit displays the folders as you want – but only one level (so you can have one folder per album/playlist but not sub folders within each folder. I’ve found I had to use a FAT sorting utility to get the stereo to see the folders in display order rather than date the files were created.
                The previous unit I had was a “Sendai” from Halfords that was about £50 with free fitting. It had bluetooth, USB, SD card, Aux – and worked really well – the folder display was as per the pioneer (so OK).
                I remember on the old MM forum someone linked an Aldi unit that was I think a tenner with similar functionality (their deals are never permanent though) so you can get decent, cheap head units.
                Based on “Verified Purchase” reviews on Amazon this one looks worth considering – especially if you are in time to return the current one. No CD player but I haven’t used the CD slot in mine for the last 3 stereos.
                #5568
                  I think your confused about the product John. The device if for cars without Bluetooth. All it is is an Bluetooth receiver that plugs in to your cars/headings aux input.
                  I think he means of your phone doesn’t have BT its not worth it.
                  My car doesn’t Come with ,not without a 700£ optional extra. So I just got the above to give the car a BT connection.
                  All you need is an aux port for audio input, and a low voltage USB or 12v output to power it.
                  #5575
                    Blacklion I have had a few problems with this (under warranty) last time I spoke
                    to the seller I said I would put up with it.
                    The one on the link looks a good deal (no detachable front panel)
                    Duke I have got BT but it doesn’t work, I get your point and could use Aux.
                    #5577
                      Up to you of course John – but if it aint doing what you bought it for I would request ideally a refund but at worst a replacement – you may just have a bad unit. Can’t see any feedback for the one you bought so hard to know.
                      The detachable front panel is likely so cost a fair bit more. Filtering Amazon results on “Verified Purchase Only” helps, but even those are getting diluted by people who have “got them at a discount”.
                      Out of interest have you tried pairing a different bluetooth device (even borrow one)  to make sure the issue isn’t linked to the phone/compatibility – it may be an issue (shouldn’t be I know). When I ran Cyanogen on my S5 there were serveral versions where bluetooth was very erratic.
                      #5578
                        I know your BT isn’t working. That’s why I offered you a 3rd party cheap and simple solution.
                        As BL said, it could be the phone BT , and your head unit BT is actually fine.
                        Or, what version of BT is your phone? And what version of BT is the head unit. I’m only asking as newer phones with BT 4.0 will not connect to the older BT 3.0 standard.
                        My old I stalled  parrot system ran v3.0 and about 3 years ago, maybe the origanal moto g was first v4.0 I had, but it wouldn’t contect to my parrots over version. Check what version your head unit is running, and your phone, they may be incompatable.
                        So you’ll need to update one or the other, or but a compatable dongle like I suggested above.
                        I’ll take a punt and say your head unit is running the older  v3.0.  I don’t know what phone you have, but if you visit GSM arena and search the specs of your phone it will tell you what radio and version of the of BT  your phone has.
                        Another theory, – Did your current phone ever connect to that head unit? If so, has your phone had an OS update lately, or rather a Play services update lately? As I know Bluetooth settings have not long been tweeted with via play services on the pixel. Maybe an PS update broke yours?
                        Ether way, find out what specs everything is running on, and you’ll be able to pinpoint the issue and offer a solid fix.
                        #5579
                          Thanks Blacklion
                          I would say for what I paid (not todays price) it’s not worth posting it back yo China.
                          I find a fair bit more, cheaper than a window.
                          That’s a point, she recently had a new phone, it workrd all the time with the old phone.
                          The old phone being Nokia Windows 8, the new is HUAWEI
                          Good points Duke
                          I wouldn’t know what BT version is, the phone has worked twice on this unit.
                          HUAWEI P9 Lite VNS-L31 pinned it down to
                          BT v4.1, A2DP, LE
                          http://www.gsmarena.com/huawei_p9_lite-7983.php
                          My orders on Aamzon links to the unit above, however mine is a Portlander 1188B
                          Searches bring up BT v2.0
                          So maybe that’s why, I think we’re (you’re) getting their for me. It seems I need a better BT Version. Here’s me thinking BT is BT.
                          #5581
                            That it has worked twice muddies it a bit. But I’ll guarantee you the dongle above will fix your issue.
                            You car will just give off two BT signals, your phone will see them like it does multiple  wifi signals. Just set your phone to auto connect to the new dongle BT signal. And tell it to “forget” the old head unit BT signal. Then when you get in your car it will just connect,if you have your BT always on. I have an nfc tag on my in phone mount that launches maps and turns BT on https://goo.gl/photos/CfQ6GfB6CgC5LYav8
                            Good thing about the dongle, is you can move it from car to car easily, unlike head units, so this dongle could last you a decade. Admittedly it isn’t as “clean” a solution as a new head unit, but it’s much quicker a job and can be taken with you on your next car.
                            #5584
                              The dongle is the best choice then, I will get one, I think I have a USB charger?
                              #5585
                                If your head unit has a USB input, it should have enough power to run the dongle. If not you’ll need a 12v to usb out. Like the one below.
                                you don’t actually need one of this caliber, any cheap one will do. (try the pound shop). I have this one as it’s very powerful and will ram power into my phone. It’s a very good one and is flush fitting, with dual USB outputs so you can power the BT dongle and charge your phone /sat nav/etc.
                                Edit forgot the link lol.
                                AUKEY Car Charger, ULTRA COMPACT Dual Port 4.8A Output for iPhone iPad Samsung & More – Black https://www.amazon.co.uk/dp/B00M6Q83B4/ref=cm_sw_r_other_apa_d.w2yb7Z4FM4V
                                #5605
                                  Thanks Duke
                                  The unit has USB, just as well you reminded me of sat nav. The sat nav I have uses the fag lighter (not USB).
                                  If one of this caliber is good enough for you then it’ll do me.
                                  #5608
                                    It’s not the cheapest option, not the dearest either. But is a good one.
                                    #5636
                                      Great stuff
                                      I’ll be sure to let you know if it’s a good one, may be not as I have never experienced a bad one.
                                      #6117
                                      Robin LongRobin Long
                                        @knightmare007
                                        Forumite Points: 12
                                        Well looks like I’ll be ordering a Anker SoundSync soon is possibly a better review.  Looking at John’s problem since this device can be powered by the head unit and provides input via aux and not Bluetooth it should be compatible certainly looks like a less destructive was of introducing Bluetooth to my zafira
                                        Cheers Knight,
                                        RIP Spike09 Your Missed
                                        If I'm not here, I'm there.
                                        #6180
                                          I have put it on hold, further investigation required.
                                          The Aux part of my car radio takes the volume from the source. So if the Anker has no volume control it uses the mobile phone volume. To turn up the mobile phone volume I get a warning (on the mobile)
                                          So the playback volume via Aux on the car radio is very poor.
                                          Maybe back to the drawing board, unless the Anker has good volume output.
                                          #6183
                                            John if you are not rushing take a bit of time and monitor ebay. Lots of real bargains on head units come up on there as people upgrade (or put the stock units back in before selling) etc. If it is not worth returning your unit you could offset another buy against selling yours privately (specify bluetooth is flakey).
                                            I’m sure you’ll find something very cheap that fits the bill in days or weeks rather than months.
                                            Bluetooth does some odd stuff….and often leads me “life is too short” decisions to work around/avoid rather than get to the bottom of it.
                                            As an aside car stereo theft round here has gone right out of fashion, can’t remember last case I heard for years – only mention on the basis “is the removable faceplate really necessary”…….if it is still widespread in your neck of the woods fair enough, but if not a cheapie alternative head unit may solve your problem.
