Forumite Members › General Topics › Home and DIY › Electrics › Bush Auto Washing Machine
- This topic has 7 replies, 4 voices, and was last updated 7 years, 11 months ago by
The Duke.
April 20, 2018 at 9:47 pm #19888
My washer went through the spin cycle but the washing was still ringing wet.
I took the filter out and it was clean, about a litre of water came out with it.
Could that mean, although the filter was clean it was blocked.
I hope so, but it’s a bit late to try now.
JohnApril 21, 2018 at 9:57 am #19895One product we always have 3rd party insurance on is the washer. We use ours minimum 4x a day. We can’t afford to be out of one. And new washers are terrible.
If the cleaned filter doesn’t fix it, it may be the pump. In my experiance it’s always the motherboard. Our old (2008 so not that old) had its mobo replaced 3 or 4 times a year. By the time we ditched it, 2012 it was literally ‘triggers broom’ I recon the chassis was the only original bit.
Our current washer went down on Xmas eve 2016. domestic and general, couldn’t get a fix out until jan, so they sent us a new replacement the day after boxing day.
Xmas eve the prior year the oven packed in. One year before we lived here, 2003, the boiler packed in. Me and Christmas don’t get on.
April 21, 2018 at 11:04 am #19896If you can hear the whirling noise from the pump then the outlet is likely blocked, it the pump is silent then it has likely failed or been jammed. They are not too expensive and can be changed by some one who knows one end of a screwdriver from the other and what a spanner is and does. Pliers my also be useful to release the hose clamps.
However, if it is the timer/programmer or motherboard things do get expensive, quickly.
Our machine also gets very regular work outs two or three times most days, some times more, but generally they have held up OK; I think the current one is only a couple of years old but probably already had more than UK average use.
It is always a struggle to decide to fix or replace a machine, unlike Steve we have never gone in for insurance, usually the insurance costs over three years could fund a new machine and most of our machines do 8 ~ 10 years. So it worked out cheaper to buy even if the machine was a bit more expensive than average.
April 21, 2018 at 11:50 am #19899The only washer that we had that held up was some unknown brand we got second hand for free. We had that about 8 years, with zero issues. We got a £3-400 hotpoint job that just failed a often, so we took out insurance before the 24 month garantee ran out. And when we replaced that, just swapped the old HP washer on for the new.
The new one goes down probably once a year. So £8pm is worth it, as I’m not good with time sensitive job (lol understatement), and tbf we have defo got our monies worth.
If we never had the kids, it would be different. If I lived alone I’d do my washing in the bath each night, and Swap washer for a dish washer. Two dish washers in fact, One for clean dishes and the other for dirty ones.
April 21, 2018 at 12:51 pm #19904IF the pump is silent then as Richard says it is likely failed/jammed. Do not leave it in that state as it will quickly go from jammed to failed as the windings burn out. Equally, leaving it in such a state is a moderate fire risk.
April 21, 2018 at 1:04 pm #19907The most common pump that I have encountered is a synchronous type with a coil on the outside and a driven shaft with an iron mass on it to move the impeller sealed in a water proof container. They are fractional horse power devices so can be quite easily stalled, though once they are running the iron mass helps them to keep running, though inertia could slow down their initial spooling up. So a rusty shaft, a few bits of crud and a stall can be the result.
April 21, 2018 at 7:41 pm #19922Thanks all for the reply’s much appreciated.
I have insurance, I didn’t want to use it if it’s only the filter. On the spin it seemed to be taking longer and didn’t seem to fast spin..
After putting the filter back in, I spun the bath towel and it seemed to be spinning as per.I need to do a full wash to be sure.
The filter didn’t appear to be blocked but water came out the as I took out the filter.
I hope it’s ok now, further testing required before I use the insurance.
JohnApril 21, 2018 at 7:46 pm #19923One thing that has always annoyed me about washers is the placement of filters and the manual water release placements. They should be higher up, and have some form of manual pump. I’d rather stand there an hour pumping water out, than it’s dumping a load of water on my wooden floor! Then me usually emptying a full dirty washing basket to soak it up quick, then mop then attack it with a hairdryer for 30 mins.
I said the dirty washing as that’s always the first thing on hand, when the things leak.
