Browser Leaks
Forumite Members General Topics Tech Security Talk Browser Leaks
  • #11305
      Browsers leak installed extensions to sites
      “All browsers protect extension data from being accessed directly by websites visited in the web browser. The past has shown however that sites may use various techniques to scan for installed add-ons.
      Security researchers have discovered flaws in the extensions systems of all modern browsers that attackers may exploit to enumerate all installed browser extensions.
      The attack affects all modern browsers. The researchers confirmed it in Chromium-based browsers, and believe that it affects other browsers like Firefox or Edge which use the same extensions system as well. Firefox’s legacy add-on system is also vulnerable to the attack.
      Chromium-based browsers like Google Chrome, Yandex and Opera, and Firefox-based browsers like Firefox or Pale Moon, and Microsoft Edge, are affected.”
      https://www.ghacks.net/2017/08/29/browsers-leak-installed-extensions-to-sites/
      Are you identifiable by extensions, logins and your browser?
      https://www.ghacks.net/2017/04/05/are-you-identifiable-by-extensions-logins-and-your-browser/
      Firefox resource URI leak Fix
      https://www.ghacks.net/2016/06/12/firefox-resource-leak/
      “The add-on No Resource URI Leak has been created to block websites from accessing resource files. Simply install it in Firefox to block websites from accessing resource files. The easiest way to verify that the script is indeed working is to run the Browserleak test. If it returns no information, the add-on works as intended.”
      https://addons.mozilla.org/en-US/firefox/addon/no-resource-uri-leak/
      #11310
        Thanks Wasbit, I have checked those out and installed necessary Addons. This is something I knew zilch about, thanks for the education! Apparently I have a uniquely identifiable fingerprint. Should I be concerned?
        #11313
          +1
          #11321
            I always thought it a given your browser and extensions was leaking data. Not something I’m overly concerned about tbh. I only have a few extensions, and funny enough the ones I trust the least are the ones that claim to help, like flash toggle ext and add blocker, that I don’t like  having installed, (I think it’s morally wrong) , but sadly needed on some systems.
            #11352
              Further update :2017.08.30
              Firefox WebExtensions may be used to identify you on the Internet
              https://www.ghacks.net/2017/08/30/firefox-webextensions-may-identify-you-on-the-internet/
