Boilers, Radiators and Quotes!
Forumite Members General Topics Other Stuff Boilers, Radiators and Quotes!
Viewing 20 posts - 1 through 20 (of 58 total)
  • #3765
      Hi all,
      Some of you may remember that I was in the hunt for house-buying. And I have finally got the keys!
      So after the wow of being a homeowner and paying all the taxes for it, the real paying for renovation starts. First on the list, the heating system.
      The current system is an Electric Immersion heater and tank for hot water and a Blown air heating system. The heating works wonders for the kitchen, the bedrooms, but it is absolutely pants in the Living room. I can be roasting in a bedroom, but freeze in the hallway and the living room. So I’ve gone out and got myself a few quotes.
      1. British Gas: £8.5k (!)
      2. JSM Heating: £3.8k
      3. Buttco: £6k
      4. Recommendation from a work colleague, who seems thinner than a pair of wood planks: £3.5k
      Quite the range as you see. I’ve done my best to study the details of each (where possible, option 4 has all been done by text message), which has been interesting at the detail some go to. British gas uses the technical terms of “small” “medium” and “large” radiators, the others detailing the actual sizes. Option 3 seems to have favoured slightly taller (700 vs 600) and K2 and K1 radiators. Whilst Option 2, has gone with K1s, a couple of K2s and a P+.
      I’m preferring Option 2 as the impression he has given is competence and talking to me, whereas Option 2 did quite a bit of sales pitch at me (“Just come from a place, really good. I have one of these, it’s fantastic” etc).
      But the main point of this post is, the boiler itself. I’ve noticed that BG has gone with the most powerful boiler (all Worcester Bosch) at 34CDi, whereas Option 3 has gone with a 32CDi and Option 3 has gone with a 30i (14.3lt/min vs 13.1lt/min vs 12.3lt/min).
      Having never measured my hot water usage in terms of litres per second, it could be quibbling over a tiny amount, but as this a one time big purchase, want to get it right. Any assistance in interpreting this?
      #3766
        Congratulations on your new place I hope you will be happy and settled there.
        I assume that you are having a combi boiler, I have no personal experience of them but my father did and found it was a mixed blessing. The flow rate is quite important as it can affect how long a bath, wash hand basin, etc takes to fill. With a combi you are limited as to what sorts of shower you can have. I have a hot water tank with the option of using the immersion heaters if the boiler is out of service for any reason. It is also easier with multiple users as there is less pressure drop when more than one tap is used.
        If the boilers are all Worcester Bosch, do check to see what level the installers are, a Gold level dealer can give you an extended guarantee on the boiler.
        I was used to seeing radiators quoted in BTU (yes I am not up to date; the units have probably changed to KW or some such) and being matched to the room floor area/cubic capacity. There are tables that the installer should be able to show you.
        I assume all of the radiators will be thermostatically valved, I think it would be classed as a crap install otherwise. Will you want a remote control option for them?
        BG are usually between 2 and 3 times other quotes and often use a local contractor to do the work anyway so cut out the middle man. (The chap I used a few times worked privately but have BG branded dust sheets…)
        An over size boiler will never reach good efficiency levels as the return water will be too warm to generate good condensation, at the last inspection mine was running about 89%.
        Do check they fully understand and allowed for a good condensate drain.
        Many younger users want to be able to either have or have the option of adding remote control. Would this be of value to you or of interest to you and do any of the quotes allow for it/include it as quoted? Would their offering be what you would be interested in having? It was not of any interest to me since the house is occupied 24 hour per day, but for those who work it might offer attractions that are not relevant to me.
        #3770
          Siting a combi-boiler in the ‘correct’ place is an art. The first item is the positioning of the flue. Many older installations can no longer be reproduced due to new carbnn monoxide risk legislation. The second more subtle problem is the boiler condensate blow-down line. This effluent has a high concentration of dissolved acids, and if improperly routed can either dissolve mortar/cement or get frozen solid – if the latter your boiler stops working in the middle of winter. If poorly routed it can also get into problems with air-locks. I know of at least two friends who have found themselves tearing their hair out over their combi-boiler. breakdowns
          Bottom-line not a job for a ‘Gas Safe’ cowboy, find someone with a good reputation (not necessarily BG as they have been known to occasionally employ incompetents just like any other large organization).
          #3774
          SteviePStevieP
            @steviep
            Having similar problem myself but with different circumstances. House is 23 years old, bought from new, and boiler is the original Ideal Classic. Works fine and is serviced every year. Now on a fixed income so looking at reducing costs, so thought aha!! new boiler. The original is bound to be inefficient compared to the new ones. So had one guy round and it appears that all new Worcester Bosch boiler flues must have at least 600mm clearance from other flues and obstructions. Any seals/weld/joins in the flue pipe must be accessable to be inspected so that would mean re-routing my flue completly or cut big holes in my walls. The only problem is to re-route it would probably mean another 2-3000,(conservative estimate there), on top. So in all about 5-5500. How long to recoup that money in gas saving? New laws and regulations sometimes don’t make life easy. Got another couple coming round to see what advice they can offer. I shall wait and see.
            #3775
              Stevie, while I understand your concern the regulations are in part a sop to the environmental lobby (mainly the ‘mental’ part) and partially to the lax way that some installations were killing people. The new equipment does need very careful positioning, but I do not think a working boiler should ever simply be junked to ‘save money’. From the studies that I did it should only ever be replaced when it is clearly end of life. The payback has to be reduced by the cost of servicing, both human and the money servicing. A possible saving of say £300pa less servicing costs, less the costs of servicing the financial outlay will rarely come out to a positive result. Positioning the boiler on an outside wall with a suitable location with respect to drainage and winds together with the plumbing is always something of a trade off. The requirement for flues to be sealed against leaks, yet be accessible for maintaining was directly the result of poisoning cases. Old flues can be lined (and old ones usually should be whatever is being done), but that does cause an issue with the need for visual inspections. Wood burning stoves have started to be a threat if not correctly installed.
              #3779
                Unless it’s a big house, 3.5k seems about right. 8 years ago I payed a local plummer (man from our pub) 2.2k to do our place. 4bed place
                If you know the man well who recomended you the local guy, I’d go with that ad he is the only one that has come as a recommendation.
                Also even if BG was even remotely close to what it should cost, I’d stay clear of them,if heard no end of bad stories.
                Also so the local guy will know loads of local plasters, sparks etc, so he will be a good source of knowledge. For some reason plasters all like a drink, and will fit jobs in for cheap before opening times.
                Lol 8.5k taking the pee. Even if the guy that is local, isn’t a tidy, you have 5k change, to tidy up and issues that may arise. Which I bet non. Plumbing isn’t hard, you can do it or you can’t. The only diffence will be time, the local age and a mate, will take 3 to 4 days, BG will throw a few people at it and take 2 days.
                Regarding boilers, you don’t always need the biggest boiler, you need to work out how many rads of what size, and that will give you the size of boiler you will need. Though I’d tell whoever, that you may wish to add one or two in the future, just to have a bit of overhead. Still even with the possible additions factored in you may not need the largest.
                You could lwork out which boiler size you will need by multiplying 1.5kw by the number of rads, will give you a ballpark figure.
                #3784
                  I checked out our recent boiler. Bear in mind all houses are different and this one is about 25 years old and does have more insulation than it was built with but we have a Worcester Bosch Greenstar 24Ri with a rated output of 24kW. It is a five bed house with two main bathrooms and a cloakroom and the boiler is far from stretched to keep us warm. You may need a higher peek output for a combi-boiler due to it having to meet the instantaneous demand for water, we have the hot water storage tank to buffer the system. I am sorry that I do not have any planning guidance to point out the differences. We have 17 radiators suggesting that Steve’s suggestion of 1.5kW per rad is about the right point, (17*1.5kW is 25.5 kW); three radiators are towel rails. not all radiators are the same size and some may have been installed to produce a more even heat distribution in several rooms.
                  It is worth checking the existing insulation as this has a good payback if it needs to be improved, a day’s DIY can reap wonders.
                  #3802
                    Thanks all for the input. There are 8 radiators in total, Bathroom where bath and shower will be supplied by the boiler, no power-shower. Downstairs loo and kitchen will all need hot water (unlikely all 3 will need hot water simultaneously admittedly), so going by the reckoning it may be very much capable. But I’d suggest having a more powerful boiler would allow it to achieve the same heating capacity at much less strain to all the components, rather than requiring the boiler to be running at nearer a peak level.
                    Insulation seems to be in pretty good order, though I think the bits under the roof could do with a checkover as at least one piece has fallen away from the roofing.
                    The position of the boiler will be in the upstairs cupboard where the hot water tank is currently living. None of the people that came said this would be an issue. It would be on an “outside” wall (outside to my property, but the adjoining wall to the house next door), vertical flue up to the roof. Condensate drainage can be linked to the bath which the cupboard is beside.
                    I’ve also just noted that I’ve done a type in my original post:
                    I’m preferring Option 2 as the impression he has given is competence and talking to me, whereas Option <span style=”color: #ff0000;”>3</span> did quite a bit of sales pitch at me (“Just come from a place, really good. I have one of these, it’s fantastic” etc).
                    Option 3 is the one that played up a bit of a sales pitch, whereas Option 2 came and gave me a good quote and listened to what I was looking for.
                    #3807
                      Loft insulation is cheap and you can never have enouth. You can or could, get gov grants to cover the cost, or prtial cost, for both cavity and loft insulation. Though this may be on a county basis.
                      Sadly my house being over 100 has no cavities, and with lost insolation being so cheap, I never bother looking into the grant in my area.
                      About every second or third  year since I’ve lived here, I’ve added to the loft, Xmas gone being the last, and I think 6th layer. I boarded over it, or as usual, 2/3s done. Need to get back up there and lay the final 3rd.
                      Ironically for this thread, it’s the old header tank that stopped me, I ran out of time on the run up to Xmas, I literally worked upto Xmas eve evening. And had to put all the stuff, I had in the lounge back in the loft. As usual I never got started again once the festivities was over.
                      #3808
                        Cavity walls have already been done by previous owners, but will look into getting the roof insulation redone.
                        After further research on the boiler decisions, I’m going to push for a Worcester-Bosch Greenstar CDi boiler. The I series initially recommended by Option 2 is good, but the CDI contains extra efficiency technology and can provide a touch more heating capacity. It is also able to intelligently tune itself, whereas the 30i will just pump out it’s maximum heating capacity regardless.
                        #3809
                          <i>Sounds like a plane. Get your self a nest thermostat or one of the salus wireless jobbies, they learn from your habits and you can adjust them on the fly. I have an old Salus wireless one, would like a newer more clever but they are a little steep. If I was getting the heating fitted I’d defo go for one. Well I did at the time and got one of the best avalible, but 8 years is along time. </i>
                          Alot of companies do the the smart thermostat now, so look around. Honeywell, hive, nest, Salus plus many more. All seem to be in the £100to 200 bracket.
                          Mine is around £30 now. Which I think is good value. It’s really simple to use, basically program the times you want to to come on, but add exceptions if the tempts above a set value it won’t come on. It’s wireless, so you can move the actual control unit around with you, untill you find the best fit for you.
                          You may also be intrested I’m smart valves for each rad, that they are quite expensive, I think Yi’s Xiomai ones are about £60 each, normal vales are around a tenner. Bit then you can set values for each room, so you can heat just the rooms you need, at the given set values. The £60 is probly a good investment, if a costly one. On your case £540 minus £90 (cost of standard ones that have been costed in). Maybe easier to stomach if you take BG quotes as the yard stick, but take the 3.8k offer up, boosting it to 4.4k.
                          I’m just chucking ideas about. I’m sure you have a referb list that far outstrips your purse at this point. We have had our house almost 15 years and its still not done, sadly they never are as long as you have a women!
                          Update these look good, they have Ifttt integration so you could set Google assistant or amazon elexa up to operate them, ie “turn lounge rad up to 18 degrees” or “turn all rads to winter mode” that sound quite cool.
                          #3812
                            Do you really need all this expensive stuff?
                            We just have manual TRVs on the radiators and that controls the room temperatures just fine. We don’t need it to be exactly 18 degrees here and 20 there. On the rare occasion a room is a bit too cold you get off your bum and turn the TRV up. Usually just for a few minutes.
                            The boiler controller has a separate timer on it for heating and hot water and over ride buttons if needed, which is hardly ever.
                            It’s a properly insulated 4 bedroom 3 storey terraced house and last year cost £67 a month for dual fuel (this year will be £75) so I don’t think we’re doing too badly.
                            Unlike going to LED bulbs on the electric side, IMO the cost savings come from keeping on top of your supplier rather than micro managing the heating controls. My £67 deal has just finished and would have risen to £96 had I done nothing.
                            #3832
                              I’m geek, I don’t need half the stuff I buy. Does anyone need a £700 phone? A £2400 mac book (once was) pro, or even a £1000 win laptop? not really. Do I need my lights to be wifi controlled? Of course I do, why wouldn’t I?
                              On a serious no, we do not nt need wifi controlled valve thermostat, we don’t really need central heating, we evolved for about a 50k years (or 4k if you subscribe to the bible) with out it. I have this argument with the he wife often. If we wouldn’t of had the last child, it’s doubtful we would of had central heating g installed. We was fine for the first 7 years with out it. Just put on an extra layer in the winter.
                              But i did say I was just Spit balling ideas. Letting him know what is out there. I’d say a wireless control unit is a must. It may an less wiring channels in the walles on installation, and it can be moved if you spend more time in the kitchen,loumge or upstairs. So for the extra £20 of the Salus one I have pays for it’s lf and five fold once you take labour to route the wire, and he cost of cable, which will be anywhere from £10 to £30 depending on where you want it, plus the time and effort he will need to pit the he wall right and decorate it. Thou I’d imagine the decoration will be needed anyhow. But a £30 Salus I linked to would be the bare minimum I’d expect.
                              #3846
                                The geek in me has been looking at all this home automation stuff, then the pragmatist asks what they will actually add to the experience never mind justify the costs.
                                One useful thing I have found is a wireless home alarm system we’re now doing that is cloud connected and allows you to associate IP cameras will alarm zones. So you can push pictures / live video with an alarm notification.
                                The company was bought by Hikvision last year and they’re doing a presentation at the up coming roadshow so I’m hoping the integration with Hikvision cameras / NVRs has been completed. That would allow it to integrate with existing analogue (Hikvision) systems. About half our work is dealing with legacy systems.
                                Any way back to the heating   🙂
                                I’d keep it simple to start with but make sure the controller is capable of integrating with a Nest / Hive type system for the future.
                                Then after living with it you can decide if you really do need the full Butler treatment  😉
                                #3848
                                  I’m with Steve on the wireless control panel, when the heating had to be re-done at mum’s place (all the pipes, internal and external and new boiler) it was £150 in parts + 1 days labour to put a conventional wired panel in the location of the old one, £40 for a wireless one and I fitted it in the location of the old one.
                                  It runs on 2 (iirc) CR2032 so there’s a load of them in the drawer that’s nearest to it but not needed to change the battery yet (9 months +).  Range is also pretty damn good, mum has in the past taken it into the garden and switched the heating on before she comes in for good.
                                  #3850
                                    That makes economic sense but the prices make no sense (but who cares).
                                    It was more the fancy TRVs I was thinking of.
                                    #3854
                                    SpedleySpedley
                                      @spedley
                                      I always thought bigger was better but that isn’t always the case.  My boiler is too big for the house (well, radiators anyway) and it often turns off every 10 mins because the return feed is too hot, i.e. tge boiler is too powerfull or radiators are rubbish.
                                      bG are well know for being double what you should really pay (same as safestyle windows)
                                      #3861
                                        Yea Dave, them wifi TVRs are just a geeks nicity. The prices are a bit steep atm, but alot of company’s are entering the space, so give it a year or two, and if I can get 9 and for around £200 I recon I’d have to get them.
                                        My lights are currently being  made ifttt compatable, well some of then. As well as being wifi capable, they need to operate as normal, so I’m going to use a ‘two way switch’ set up so it’s kid and visitor friendly. Probably with a pie zero or the small arduino (disk thing, easier for me to program) maybe as the second swith, which can in the light fitting or just a above it.
                                        I can use the live lighting ring to power them. Given I’m now fully LEDs the ring has literally tons of spare capacity. Plans are in my head atm. Need to make a proof of concept with a desk light first, before I get carried away
                                        #3867
                                          Thanks. Comments raised with Option 2. I feel far too nerdy to be researching boilers and suchlike, but I guess it’s something I’m going to pay a lot for so might as well get it right.
                                          I think I’ve decided to go for the Worcester Bosch 32CDi compact, a slight bump up in spec from the 30i as it includes condensing of both hot water and central heating as well as a pump that can be tailored for the demand required, rather than just on or off. British Gas recommended the 34CDi, but that seems to have a slightly reduced efficiency, plus be a touch overpowered.
                                          I’ve asked about the controls too, as initially I was unconvinced, but as Planeman says, adding all the wiring may leave it a little unsightly. I’m not sure I’m ready to pay the costs for a Nest or similar, but a basic wireless unit can always be replaced down the line.
                                          EDIT: I see the conversation has moved on a little, so to add to that, I’ve discovered I have a PIR sensor in the bathroom, which has been disconnected. I guess too many times of getting comfy in the bath, just for the light to go out! Took me a while to determine what it was. As for lighting, I need to find something that spreads the light out effectively as the living room is a large space. As I’ll need to be updating anyway, I’ll definitely be going LED.
                                          #3873
                                            I’ll try and remember to check what boiler is at mums place tomorrow, it’s a Worcester Bosch job, I’m almost certain, it’s a large sprawling house, only 3 bed, 2 bath and another bog but floorpan would have space for about 5 bed and 4 bath and the spare bog. And a bigger drive.
