Forumite Members › General Topics › Tech › Other Tech › Bluetooth audio from PC
- This topic has 6 replies, 5 voices, and was last updated 7 years, 10 months ago by
Wheels-Of-Fire.
March 28, 2018 at 12:23 am #18644
I bought myself a pair of Psyc Wave ZX Bluetooth headphones a little while back, thinking that I could use them with my phone for hospital appointments. Typically, I’ve had company every time I’ve had an appointment since…
I was thinking that I could use them with the PC, rather than having a cable getting in the way, and maybe plug them into the media PC if I’m up late in the night.
Is there a simple and cheap way to connect them, preferably through Bluetooth? Ideally something small and USB powered so that it can move around with the headphones.
I’ve looked on Ebay, but it’s either the dodgy looking stuff from China, or dongles with appalling spelling and grammar and pictures of car stereos, making me think that they’re receivers, not transmitters.
March 28, 2018 at 7:28 am #18658If your headphones are completely Bluetooth compatible any decent dongle should connect to them. link
The passkey is often 0000, but the destructions for your headphone should tell you what it is.
March 28, 2018 at 9:23 am #18663Yeah I had one in an old laptop where the internal bluetooth had packed up – worked fine doing exactly whst you are looking t do (handy for bluetooth speakers too). Any of these should do the trick.
March 28, 2018 at 11:29 am #18675Any cheap dongle or card will work. I love bt ears used 5hem now for about 3 years. Gone though about 6 pairs of teotronics £15 to 20 sets. 6 may sound a lot, but i use earsphomes about 16h a day, and the wire always wears quick or worse still the aux port.
Also when on a PC, I’ve often jumped up to answer the door forgetting to take the cans off. The wire would push everything offy desk before lassoing the fans off my head. So bt is a great opinion for all that don’t want super high-end audio.
Currently have a pair of teotronic stiffed in my lugs now. Not only do they sound decent, have a good 7 hour run time, but when off, they really block out the sound of the house. So i can concentrate on work. Currently handy for Easter break.
March 28, 2018 at 12:39 pm #18689Brilliant thanks guys
April 9, 2018 at 5:46 pm #19424Sorry, I forgot to come back to this. I ordered two – one for each computer, and they turned up on the weekend. They’re working great, and I’m looking into scripts to switch audio devices from within Kodi on the media PC ?
April 27, 2018 at 1:49 am #20093I think I should mention Bluetooth audio profiles here too.
If you want the best audio then both devices should support Advanced Audio Distribution Profile (A2DP).
If you want remote control then AVRCP is the one to have.
If neither of these are mentioned then the devices will fall back to the older headset profile which is a bit rubbish ?
