Android emulator for W10 just to use Kaizala
Forumite Members General Topics Tech PC Talk Android emulator for W10 just to use Kaizala
  • #60907
    AndréAndré
      @inversions
      Hi, there is a single chat group on Kaizala I want to join and use from my PC (I hate typing long messages on phones). I’ve Googled for it but it’s really complicated and I just want something easy if it exists.
      Is there an at least fairly easy emulator to set up? You know, like Whatsapp is easy kind of thing.
      I’m not a total dunce but some of the stuff I was reading about the emulators just really put me off!
      #60917
        I’d never heard of Kaizala, but the first google result suggests that there is a web client and therefore you shouldn’t need an emulator. – link.
        If that doesn’t work or isn’t an option for whatever reason, there’s always Bluestacks.
        #60919
          I doubt if it fits your needs but there is a vm guest for x86.
          Link
          [edit] The isos can of course be used in both virtualbox and vmware. I’d be interested how you plan to use such an emulator. I have a copy installed, but to be honest I looked at it, shrugged my shoulders and forgot about it.
          #60922
            Me too. I thought it may be a good way to run the Hik Connect CCTV app on a PC as the PC app is a full blown VMS affair. It’s proved far easier to just run things on my android tablet or the iPad and move clips to my server via a Synology file app.
            #60956
            AndréAndré
              @inversions
              I’d never heard of Kaizala, but the first google result suggests that there is a web client and therefore you shouldn’t need an emulator. – link. If that doesn’t work or isn’t an option for whatever reason, there’s always Bluestacks.
              Well that was not an easy page to find from the Kaizala home page! All I found on there was it was for Android or IOS. And my Googles were obvs not worded very well, search after search, page after page and I never found that. Thanks for the link!
