  • #33801
      Just wondering if anyone’s used it, or has any thoughts.
      https://adguard.com/en/blog/adguard-dns-announcement.html
      It looks good, and seems to have a good reputation on Reddit, but that doesn’t necessarily mean much 😀
      #33810
        It’s the same as PiHole really. Can you have your own whitelist?
        #33815
          It looks like you can in the browser extension, but possibly not in the other options.
          #34055
            I’ve been using AdGuard on Android for the last few days, and it seems to be doing its job. It doesn’t remove the frames from the ads, but it stops the content from loading. I haven’t played with the family filter yet, but I’ve got it set up on my OnePlus One ready to test for Alice.
            If you set it up using the private dns setting on Oreo and up, it works on the mobile connection too.
            There’s no whitelist option that I can see, but to be blunt, other than a handful of sites like Forumite, I’m not bothered, I’d rather save my data. I’d prefer the whitelist on the computer though.
            #34056
              Another option is to use a host file system. This is a Python FOSS program on Github:
              link
