64 Bit AAArch64 Pi
Forumite Members General Topics Tech Makers & Builders Raspberry Pi 64 Bit AAArch64 Pi
  • This topic has 4 replies, 2 voices, and was last updated 6 years ago by Ed PEd P.
  • #41095
      I know that Dan likes compiling kernels, however this blog shows that there can be real value in compiling a 64bit kernel for the Pi.
      #41098
        I’m sure that Dan will not need it but for others a how-to for RPi3 can be found here:
        A couple of things to note. First the build will not work on a P1 or Pi2 as they have the wrong architecture. Second, I’m also reasonably certain it will not run as shown on a Pi4 because it has different boot code. For the pi4 you should start on the git hub 64 bit kernel instead
        #41244
          The thing I took away was wire guard . I’ll be changing my vpn server from open vpn once I get a minute.
          #41250
            Sorry, it looks as though the git hub link was screwed up. It should be:
            https://gist.github.com/G-UK/ee7edc4844f14fec12450b2211fc886e
            #41265
              If Dave’s WireGuard comment hit you out of thin air – this article may help.
              There is a specific how-to for the Pi here.
