Forumite Members › General Topics › TV, Film and Music › TV › 256GB USB Drive
- This topic has 11 replies, 6 voices, and was last updated 7 years, 9 months ago by
Richard.
June 8, 2018 at 7:37 am #21666
I think maybe Dad has bloomered, checking about the TV he has purchased.
I think it records to USB, I don’t know the ins & outs.
Are 256GB USB Drives reliable enough to record TV programs (on the above TV) regular, like an HDD on a Freeview recorder box.
I once purchased a 256GB USB drives, to find not reliable.
Should I tell him or leave it as is.
JohnJune 8, 2018 at 7:53 am #21668Why not use a USB hard drive? It’ll probably work out cheaper per GB and he’ll get more space.
June 8, 2018 at 8:36 am #21669That’s a thought Drezha, it will have it’s own power.
I will look into that.
JohnJune 8, 2018 at 9:14 am #21670Until mum got Netflix and Amazon Prime I used an old ssd in an enclosure hooked up to mums TV so she could record stuff from her Samsung TV.
Before you buy anything do some googling, not all HDD’s play nice with all TV’s, same goes for flash drives.
June 8, 2018 at 5:39 pm #21684Thanks PM
Good advice not sure what to look for I did think a 3.5″ HDD Enclosure with a WD 500GB HDD. But then would it do for the TV.
I need to look for one that’ll play nice with the with a Toshiba TV.
I am struggling to find any recomendations.
JohnJune 8, 2018 at 6:46 pm #21688It’s states usb recording so it should work. And enclosures are cheap.
If it doesn’t work Large USB hdds are relatively cheap, I have an Samsung 1tb job that was about £40 2 years ago. And it’s quite amazing how many movies will fit on 1tb. Totally overkill for a DVR but the price form 500gb to 1tb is a couple of pound at most.
June 8, 2018 at 8:58 pm #21691Thanks Duke
I will look into USB Drive and see what’s about.
JohnJune 9, 2018 at 6:44 am #21694Try it out with a cheap usb3 stick first.
June 9, 2018 at 7:54 am #21696Until mum got Netflix and Amazon Prime I used an old ssd in an enclosure hooked up to mums TV so she could record stuff from her Samsung TV. Before you buy anything do some googling, not all HDD’s play nice with all TV’s, same goes for flash drives.
Was that down to some USB drives drawing their power from the TV and the TV not really supporting the requirement? If so device with its own power supply might avoid that issue, but as ever suer experience should be a guide. I also wonder what drive formatting the TV would understand/accept, that could be another point to check.
June 9, 2018 at 8:21 am #21697It was a powered caddy, had a wall wart similar to a phone charger but proprietary. It was down to the TV being particular about certain devices, I suspect they really wanted you to use Samsung ones. It also had to be FAT32 formatted.
June 9, 2018 at 8:35 am #21698Thanks Ed
I tried it with a USB 32gb Sandisk (USB2) and it records fine, not sure if it will except
500gb HDD.Dad has found another problem he can’t handle
(I did tell him it only had a single tuner he could only record one and watch the same)
He was recording Emerdale and tried to turn over, giving a message this action can’t be done.
On that he has gone back to freeview recorder box (2 tuners) and left the TV recording.
Richard (just to say) when I inserted the USB stick it said format unknown, do you want to format
I said yes and it formatted, so the TV uses it’s own format.Cheers
JohnJune 9, 2018 at 9:13 am #21699John, OK at least that is not a problem and perhaps useful to know for the future. Maybe that is why some TV <-> drive combos do not work well.
Richard
